Old 11-01-2005, 02:49 PM   #1
eed-250
eed-250's Avatar
Default Can you guys clear sometihng up for me.
Hey guys, i got a set of AU pursuit rims and i put my old 225 X16s on them.
Now im takin it down the drags on wednesday and i just wanna make sure it is safe to run AU rims on the back of my ED.
has anyone done it? They fit on the back tho, but i was told they have differnt toe in or some shit? When u try rotating them when there on the hub, it takes alot more energy to rotate them compared to the E series rims.. if thats useful?
eed-250 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2005, 03:06 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
i can't see it making any difference personally...
if it was taking corners then i would imagine they'd be a bit iffy, but for drags they'd be normal.
never heard of anyone doing it.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 11-01-2005, 03:30 PM   #3
niko
likes falcon's
niko's Avatar
they sit in more closer towards center of car shouldnt make to much diff
www.carhubsales.com.au
Old 11-01-2005, 06:31 PM   #4
Psycho Chicken
Psycho Chicken's Avatar
Just get some washers from Bunnings and put them on the wheel studs to pack it out a bit.
Old 11-01-2005, 06:36 PM   #5
LUXO_8
windsor user
LOL dodgy!!!!!!!
Old 11-01-2005, 07:35 PM   #6
Walkinshaw
Two > One
Walkinshaw's Avatar
On the back you wont have a probelm.
Old 11-01-2005, 07:43 PM   #7
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
just as long as they arent too close to the body or any other panel, and dont rub i would think they would be fine.
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2005, 11:49 PM   #8
eed-250
eed-250's Avatar
fukn good idea.
my car is king of dodgy!!
cheers mate
Old 12-01-2005, 09:21 AM   #9
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Toe in refers to your front wheel alignment (suspension setting) not to an actual rim.
Check if the rim or tyre is rubbing on anything - if it's not you're ok. If you're worried about being pulled over, change the rims at the drags.
Old 12-01-2005, 01:14 PM   #10
eed-250
eed-250's Avatar
yeah i was going to do the rims at the drags..
another problem is im using my mag wheel nuts (which are quite long) and they stick out a fair bit on the AU rim... is that ok?? should i get some AUfalcon? wheel nuts or not? Will it be safe?
Old 12-01-2005, 01:25 PM   #11
EFFalcon
Last warning
EFFalcon's Avatar
just get some open ended nuts to put on as are on stock rims.
Old 12-01-2005, 01:27 PM   #12
eed-250
eed-250's Avatar
where do u get em from?
Old 12-01-2005, 02:18 PM   #13
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
any tyre shop. I would recommend the new wheel nuts as you may not pass scruitineering with the long nuts.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2005, 02:23 PM   #14
eed-250
eed-250's Avatar
thanks...
better go out n buy some then. haha
cheers
i was gonnna put the rims on after i passed scruitneering btw :P
Old 12-01-2005, 11:29 PM   #15
Fairmonty_Python
Jesus drove a Falcon
AU rims have a different offset to E-Series rims. I'm not sure which way, but several tyre retailers have all told me the same thing. If you want to know the exact answer, talk to them.
Fairmonty_Python is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2005, 11:47 PM   #16
hornet
hornet's Avatar
I passed scruiteneering with a broken back wheel stud!
Changing wheel studs is a pain in the ***! 1 hour job for a $5 part!
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2005, 03:32 AM   #17
eed-250
eed-250's Avatar
ok raced and it was all good.
Just to clear it up, the AU rims fit fine, but they sit so far into the guards, makes the tyres look thinner. haha
i used the mag wheel nuts which stuck out heaps, did burnouts and all that shit and everything was sweet.
Cheers for the help!
4.0Lturbo
T56
AP Racing
520rwhp
Old 13-01-2005, 09:17 AM   #18
EFFalcon
Last warning
EFFalcon's Avatar
Good to hear ;)
good times for the night? :P
Old 13-01-2005, 09:51 AM   #19
outback_ute
Ute Forum Moderator
Contributing Member
Yep, glad it all worked fine but how did you go?
Old 13-01-2005, 10:46 AM   #20
tickford2001
does anyone know off hand how wide the AU / BA rims are? ive got some 16" competition tyres that i wouldnt mind fitting on to a set of rims just for use at the drags, and the au rims might be a cheap way of doing it!
Gone cruising
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2005, 11:44 AM   #21
eed-250
eed-250's Avatar
AU rims are 16s mate so yeah they should fit!!
I was running 225/50/r16 on my AU rims.
yeh got a 14.8 woohoo although its only 2kmh faster then my previous 15.5??? All due to my shitty top end caused by an ignition problem i guess.. it was dying on its *** everytime i changed gears so yeh once its fixed it should be quicker by a fair bit..
4.0Lturbo
T56
AP Racing
520rwhp
Old 13-01-2005, 12:11 PM   #22
neb
hibernating
neb's Avatar
what mods (performance wise) have you done to the ed?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2005, 12:14 PM   #23
eed-250
eed-250's Avatar
wade 1004@112 cam, motorvator extractors, 2.5inch exhaust, volvo thermofan, 3.45lsd and cold air intake.
4.0Lturbo
T56
AP Racing
520rwhp
Old 13-01-2005, 12:14 PM   #24
Casper
Contributing Member
Casper's Avatar
no no no. Street tyres Dave or no cherry ripe. ing_sm
Older, wiser, poorer.
Old 13-01-2005, 12:20 PM   #25
neb
hibernating
neb's Avatar
cool 14.8 sounds like a decent time for those mods.. i'm guessing its manual?
my engine is really rooted... i can only get low 16s at the moment and i have very similar mods to you
