Old 20-09-2007, 11:34 PM   #1
EL_Monty
EL_Monty's Avatar
Default KH Laser Water Pump Removal
could someone give me a quick rundown on what needs to be done to get at and remove the water pump on a 1990 laser 1.6
while i am mechanically minded ive never done one before
thanks
PM
EL_Monty is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2007, 07:00 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
if you can see the water pump
you undo the belt it runs off
undo the water pump holding bolts
the pump can be can be taken off with tools
clean the surfaces use a sealant and refit the pump and belt
if the pump is internal and runs off the timing belt thats much more complicated if it is a twin cam engine and needs a trained person
My car goes Brumm Brumm
Old 21-09-2007, 11:00 AM   #3
EL_Monty
EL_Monty's Avatar
thanks dirty but i sorta knew that already......what i need to know is WHAT needs to be removed to replace waterpump ie: does the harmonic balancer need to come off etc etc
Old 21-09-2007, 02:54 PM   #4
dirty hands
Over Thinker
have to ask a laser owner not sure where the pump is located
Old 21-09-2007, 03:18 PM   #5
JOSH
JOSH's Avatar
you have to remove all the belts, then take off the timing belt covers. line up the timing marks on the camshaft sprocket and the crankshft one aswell. loosen the 12mm bolt that runs through the tensionerand with a big screwdriver lever it back so there is no tension on the belt and then do it back up. remove the belt. now undo the 2x12mm bolts that the lower radiator hose goes onto. then undo the other 4 bolts. clean surface and make sure you use some sealant on the gasket. then put it all back together. make sure you get the timing belt back on right and make sure the crank and the cam hasn't moved. hope this helps.
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2007, 11:48 PM   #6
EL_Monty
EL_Monty's Avatar
thanks josh, with your input and my skinned knuckles im now a laser waterpump and timing belt specialist.......too easy when you get good advice and give it a go.
GH
ps , if car has ac removing the ac idler pulley and lower pulley helps as well
