Old 06-11-2007, 10:52 AM   #1
trevXF4.1
Default XF Odometer problem
Hey, i have an XF 91 pano, and have just noticed the odometer has stopped. The speedo still works fine, but the area that shows how many k's the car has done, and the fuel reset k's has stopped tottaly, how do i fix it? get a new odometer cable?
trevXF4.1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 11:52 AM   #2
Lightning Strike GT
Lightning Strike GT's Avatar
There is no speedo cable in these they are electronic
Remove it - toss it out and get another one with similar KMS on it and swap it over
Regards Alan
FG GT in Lightning Strike
5th anniversary edition in manual 1 of 25
And an 2019 MD Mondeo Trend Wagon in Platinum White
Lightning Strike GT is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 12:17 PM   #3
XF Falcon
[FORCED]
XF Falcon's Avatar
I thought it was just a little plastic gear somewhere inside the dash or somewhere which breaks and it stops the odometer from working?
500 rwhp BF XR6 Turbo and 115 rwhp XF
XF Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 12:25 PM   #4
scoupedy
IS it electronic or not? If Not then they have a little gear that can slide along the axle and not contact the other drive gear then just slide so they mesh together that is what stopped mine
scoupedy is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 12:51 PM   #5
xe351
xe351's Avatar
pretty sure they are electronic (xe are) and have little plastic cogs in the speedo that turns the odometer, these loose a couple of teeth as they get old and fragile. VDO can fix and recalibrate them, about $100 i think. Another 2nd hand one may have the same problem. Its a problem with both ford and holden of the era.
XB Parts Wanted
Twin Horns 8-9/74 and lower horn dated 7-8/74, GT hubcaps. GT aircleaner. Please pm me if you can help
xe351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:12 PM   #6
dave351cid
playing in my big shed
dave351cid's Avatar
g`day trev
i had the same problem with my XF UTE and it was a small plastic cog in the back of the speedo.
i called a guy i knew on the sunshine coast that specialised in instrument repairs and he replaced the gear . cost me about $80 about 4 and a half years ago. he said it was a very common problem and he kept the parts in stock. maybe you can get the part from ford and fit it yourself ? i would have had a go but was too busy with work at the time and i had the ute on the market so needed it fixed asap.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 12:12 AM   #7
rob351
Motel XC
rob351's Avatar
Hey Trev,
I will go to superoo falcon spares on monday after my exam and get parts for in the dash for ya
rob351 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 12:37 AM   #8
gassedxf
hey trev these are fairly cheap to repair most mechanical workshops worth they're salt can have this done for around $180.00 bucks
gassedxf is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 01:08 AM   #9
fmc351
let it burn
Go with rob351's option... they are electronic, it is just a plastic cog, E series do it too.
The fault is that common it comes factory std.
Old 09-11-2007, 01:22 AM   #10
BigCav
OzFalcon.com.au
BigCav's Avatar
like others have said its jsut a pastic cog, they are made deliberatly weak so that if u try and modify them they break, but over time they get soft and brittle.
NEVER in a ford press the clear/reset trip metre while moving, this is what does it mostly.
mate if u join up www.xfalcon.com the xd-xe-xf specialists there are guys there who have made and do sell these replacement gears made from metal for about 30 bucks, the cheapest fix u will find i gaurantee. i think also if u surf eaby serch for cruising central or cruizen or something, he sells them he is also a member of xfalcon
BigCav is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2007, 11:41 PM   #11
cowboy
Cowboy
cowboy's Avatar
I bought a whole new cluster off ebay, same problem so bought another one and it was fine, two clusters was still cheaper than having it fixed (about 60 inc post).
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1930 Pontiac Landaulet
1932 Pontiac V8 sedan
1935 Pontiac sedan
1937 Pontiac 8 sedan
1948 Pontiac silver streak
1949 Ford F3 pickup
1953 Pontiac Chieftain
1955 Austin Champ
1957 Dodge Power Wagon
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
cowboy is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2007, 12:50 AM   #12
mutanti
Turbo
mutanti's Avatar
Glad my XF is Digital ( Star wars Type LOL ) i also have a spare if i ever need it...
mutanti is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2007, 02:25 AM   #13
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Originally Posted by rob351
Hey Trev,
Wanneroo to Armadale! For few parts.......I hate that drive with a passion ;)
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
