Old 14-12-2007, 03:27 PM   #1
Als_Zetec
Rated G
Als_Zetec's Avatar
Default Gearbox oil replacement on Zetec manual
Hey everyone
to the mechanics and mechanically minded out there... I've read all over the place that it's a good idea to replace he gearbox oil every 100K km regardless of make / model. This is not something that I have found manufacturers to ever recommend, which to me does not make sense - it's oil, it has a life span, it will undoubtedly contain debris as you will undoubtedly crunch a gear or two (and not admit to it in public of course!).
Thoughts on this? If it is a good idea and / or recommended I was thinking of do it at the same time as by brakes over the Xmas days off. I'll be doing it with a couple of friends, and may even get to use someone's workshop (power tools!! ).
Cheerio
Ali.
Als_Zetec is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2007, 08:53 PM   #2
Ives
Ives's Avatar
100,000km ?
Imo if you're a car enthusiast, you'd change the transmission oil much more often than once every 100,000km.
I plan to change mine on the 45,000km service.
Old 16-12-2007, 11:56 AM   #3
Imolator
Quad Cam
Imolator's Avatar
Originally Posted by Ives
100,000km ?
Well you will find it quite hard to change the oil, as no drain plug is provided. The Manual transmission is sealed for life. Ford put a synthetic gear oil in and it shouldn't ever need changing. It only needs the oil level checked every 3 years.
Imolator is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2007, 01:16 PM   #4
Als_Zetec
Rated G
Als_Zetec's Avatar
Well, there we go - thanks Imolator for the answer.
Like Ives, I'd like to change it, but if it's sealed, it's sealed!
