#1 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Just reading through the pages of those who have been blessed with the Destruction BUG
![]() in the begining XW panel Van owned for 12 years 3 motors the 1st died a natural death the 2nd threw a rod at 5 days old ..no warranty on worked motors ![]() then there was a lot of $100 rockets along the way with 3 Minis that all seemed to have clutch issues ![]() a XT fairmont I couldn"t kill it just rusted away along with a XB went the same way a 351 XY ute 2 gear boxes there in 12 months (stupid autos) a ED 5 speed Futura more clutch issues (Mmm begining to see a pattern here ![]() ![]() ![]()
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Turbo Dinosaur FTMFW
too many to list here, more diff's than I can remember...
but my most recent was destroying the C4 in my coupe on christmas day :hihi: |
Weezland
Just on my last car,
blew up a TKO600 twice,a 9" diff, dropped a valve fixed that,then chopped a cam lobe, To top it all off it finally snapped the crank in 3 pieces,and didnt that make a mess.. |
'01 AU11 XR8 UTE
yeah my ef lost the brake boster (not hard or expensive to fix, just a bugger to drive) and then it broke the pedal cluster and the clutch droped to the floor
WILLOWBANK PB BF MK11 XR6 14.175 @ 99.49mph CURRENT '01 AU2 XR8 UTE - 5 SPEED MANUAL. MUCH WORK TO DO. PREVIOUS '07 BF MK11 XR6 - 6 SPEED AUTO '95 EF XR6 - 5 SPEED MANUAL See my car HERE
I had a XE 3.3 4speed on LPG, only had the car for 12 months, and In that time.....
Cracked Head Split a piston in half Diff Blew Gearbox Blew Alternator died Starter motor died LPG converter 5hat itself. What a great car! other than that, not to bad, just a few diffs ![]() |
#6 | |||
dazed&confused
so hows the motor coming tony?
ban frangipanis beauty is only skin deep. ugly goes all the way to the bone. |
The Fun Mobile
Broke 16 C4 autos in my XD (Over 17 years).
Broke only one diff in that time. Clutch come appart at 6000 rpm and killed Toploader, 351 motor, extractors, brake lines, bonnet. Wiped 16 lobes on new motor a few years ago, which destroyed motor. So pretty good run really, as i am HARD on parts, and the caining started on the XD when i was 17 ![]()
408 cube Cleveland TFC @ AFD 2V, 750 DP 10.7 @ 125 mph 2V powahhhhh |
LOW AND SLOW
I need a new Volume Knob for the original Phillips Radio in my EA. Pretty lame hey.
Hmm Project XW VAN !!!!
First car XF S Pak.
Put a nice worked engine in. 4 Gear boxes, 4 Diffs 5 Clutches 4 dissy gears 2 Dissie's 2 Cams 1 Exhaust ( Due to back fire when Dissies let go) 1 new head after valve hit no.1 EF XR6 2 gear boxes 1 Clutch 1 Head AU XR8 Nothing I can think of....What a great car. BA XR8 3 Tail shafts (One was warranty) 4 Gear boxes (One warranty) 1 Complete Diff 3 Axles 1 Complete Engine (Warranty) 1 radiator 1 Clutch and Fly wheel kit 3 Clutches 1 More clutch and flywheel upgrade 8 valves 4 Pistons 1 Full Engine rebuild and upgrade. 2 cam bolts (separate times) 2 Cam gears (separate times) 3 timing Chains 2 Guides 3 Timing Chain tensioners 1 water pump 1 Alternator 1 Drive belt tensioner and thats all I can think of off the top of my head....... ![]() Kev
I'd rather be BLOWN than stroked Yella Terra Supercharged Power Output? ![]() ![]() POWERED BY VISA MASTERCARD AND MORE VISA (And now a mortgage extension) Disclaimer : ![]() ![]() |
LOW AND SLOW
Sheeesh. Mine is really lame now !!!
Parts bin special
a 4 speed auto gearbox in a stock EA!
I've also broken 2 front bumpers (3 if you include the one I pulled apart), 2 headlights, 2 bonnets, 1 side skirt (after dropping a set of extractors on it before putting it on the car), and something inside the engine which causes it to almost sound supercharged. It's been doing it for well over 12 months now so it can't be too major. Also my LSD diff now thinks it's a single spinner.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
#12 | ||
Broken a 5spd in my 91 barina to the point where i had to kick the gear stick with some major force to get it out of gear.
blown a xf diff to the point where everything inside was on the bottom of the diff housing. my 89 vn commie i blew the injectors all six at the same time and i had dent marks on the bonnet from where they all hit it, also its air box was no longer in on piece rather in 200 pieces. ive blown my mates 186 with a piston through the block. my 83 gj sigma copped a hiding once but only managed to blow bothe tyres. my 78 sigma motor now sold to my mates still blows tyres to the point of no tomorrow. |
It's Millertime!
Timing chain snapped in my EF with only 100xxx kms on it. It took the head with it :<
95 EF Falcon Futura. |
#14 | |||
Back to Le Frenchy
I like the way Kev did his so....
First Car - 1988 VL Wagon 1x Head and gasket 2x Diff - one stocker and one from a Turbo 4x Auto trans - they all sucked Many other little things, the thing was rubbish Second Car - 1997 EL GLi Sedan 1x Auto trans 4x T5 - Blew the same one twice but admittedly 3 were EA T5's 1x Diff 1x Head gasket 1x engine A fair few other things but it did have 465,000k when I sold it. Was a good car. Current - The XR8 1x Engine - Cyl 8 went bye bye so that meant I needed a stroker, really it did! Lots of tyres - Something to do with the stroker I believe. Nothing else really worth mentioning. I replace bits because I want to and it goes well. Very good car.
#15 | ||
Bugger
#16 | ||
nou
![]() 15 posts and it hadn't been said? Cmon, you're all getting slow.. :p |
#17 | |||
#18 | |||
Not so low, not so slow.
I would say that these guys would be the type of drivers that show sfa mechanical sympathy, and drive the cars at 10/10ths frequently. I too give my cars heaps, but as yet, have not had a major failure that has resulted in catastophy. had untold amounts of small problems tho. |
#19 | |||
Cuban... nothing like it
Ts50
24 head gaskets 8 pistons 32 rings 4000ltrs of water and coolant 2 rebuilds 35040 hours of garaged state 1 road registration 1 EPA raping
#20 | ||
I've broken heaps of things. I once destroyed the Hopper Knocker 5 poster bullbar on my ute. I've broken diffs and gearboxes. I've broken various bones (Right knee cap, Right wrist twice, Various fingers and toes). I've broken various pushbikes when I was a young tacker trying to impress the local girls by tring silly stunts. I broke a television cabinet by putting firecrackers in it (I did the same thing to a letter box once too).
My Ride... 2005 BA2 XR6 Magnet Ute. |
#21 | ||
Adapt or perish...
EA...
1 x Dizzy 1 x something that had to do with the throttle AU Mainly just panel damage, mechanically it was great. BA None yet
Carless
#22 | ||
Hrmmm
1st car , broke nothing 2nd car, broke nothing 3rd car . XB Goss special: 3 diffs ( last one within a week of going in, snapped the end of the axle off ) Clutches but nothing else... still not bad for a stocker. numerous cars 4th car of note: XB GT sedan. 12 uni ( one lasted 3 hours ) 2 clutches, 3 pushrods, around 12 engine mounts ( got good at doing them ! ) plus various other things. numerous cars XA: engine mount, head gasket, screw in stud, push rod but surprisingly little else .. probably from spending so much time idle. Sprint .. broke the steering column at winton ! Pulled out of the bearing in the firewall and made all the electronics die .. that was fun but thankfully didn't find out till the trip home. BA XR8 - 3 clutches, 1 axle, 1 diff, 1 engine mount and counting ! |
#23 | |||
Weezland
![]() Hope this one dont show me any grief,I might have to start being a little easier on it than the last, but where's the fun in that ![]() |
#24 | |||
carburettor
1st Ford Telstar 86
2 blown heads something to do with the battery and alternator have no idea and neither did the auto electrician. 2nd ford Escort 88 cracked head blew 2 pistons plenty of piston rings thermo fan seized alternator starter motor plenty of tyres ![]() massive rewiring new carby new exhaust control arms (both upper and lower) and lots of money wasted oh and a couple of rebuilds. 3rd through to bout 50th lol 100 dollar registered paddock bashers current r33 4 door skyline gts-t auto changed PFC to stock computer, changed boost setup as wastegate actuator was starting to seize. fuel filter fuel line bushes now just needs a new fuel tank and a fuel line. best car ive had to date and it was a jap car ^^^ runs well go's fast and keeps me happy. thinking it needs a bigger turbo ![]()
#25 | |||
BA GT-P Owner
![]() As for me my first car was an XR wagon, broke 100's of uni joints front and rear. My second car was an XC, i blew a C4, borg warner 35 and a single rail 4 speed. The third car was a EB S2 Spac never had a problem with it and well I guess most of u would now what i have done to the AU 2 gear boxes, 2 diff rebiulds, 1 axel, 1 clutch and 2 front end rebiulds (pannel damage).
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
#26 | ||
Blew the gearbox in my TX5. Haven't blown anything in my WRX yet and hopefully it stays that way because it's going to be way too expensive
#27 | |||
#28 | |||
i have a ford dvd with what i think might be your car on it.is this the one or what? |
#29 | ||
Living the dream
VN
1 x diff 1 x T5 2 x engine mounts Rubbish car VP Nothing... good car AU Nothing, superb car VT GTS 1 x diff ED 1 x T5 - I was planning on selling the car, so I went to a mates farm, and we bashed the living sh1te out of it, but I ended up keeping it and replacing the gearbox. |
#30 | |||
BA GT-P Owner
