Old 20-02-2008, 10:24 AM   #1
sscovill
Question 1991 KF Laser Jumping While Accelerating
Hi All,
I own a 91 KF Laser 1.6 Carby Manual.
On my way into work this morning about 15 minutes after starting off the car started to jump when accelerating. It seems most pronounced at 1/6-1/2 throttle. If I floor it it seems OK but a bit sluggish.
Also when I revved the car in neutral at part throttle it would almost stall before revving.
This made taking off quite jerky.
Anyone have any ideas on what it could be?
It doesn't happen all the time either. Maybe once every 3-4 weeks.
Sam
sscovill is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 01:46 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
second stage of the carby not working
choke problem
a vaccume leak
vaccume pot devices not operating on the carby
water/dirt in fuel filter
sticky accelerator if a cable
or a spark problem
coil cap plugs leads dissy module
My car goes Brumm Brumm
Old 21-02-2008, 12:02 PM   #3
sscovill
Thanks for the reply.
I might take a look at the carby on the weekend. Anything to look out for when I do?
Sam
Old 22-02-2008, 05:35 AM   #4
dirty hands
Over Thinker
just spray wd 40 around the carby pivot points
start the car without the air filter on and see if the top butterfly opens
see if you have a clean air filter
clean the battery terminals
pop out in the dark lift the hood and start the motor
look for arcing at the coil cap or sparkling leads
