Old 24-02-2008, 04:55 PM   #1
oysta
Escort MkII 1977 2.0L
Default Torque for U bolts and drive pinion flange
Hi All,
Took my rear axle assembly out for a good clean. Now its time to put it back in. Both my manuals (Ford and Gregorys) say to tighten U bolt nuts and drive pinion flange bolts to specified torque yet I can't seem to find what those specified torques are.
Any ideas??
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 10:01 PM   #2
aviper4u
hey i have an escort MKII 1978 will check my manual, i have it close by as i have been trying to solve the mystery of the missing coolant for a week now....
aviper4u is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 10:11 PM   #3
aviper4u
looking at the rear axle chapter of my manual, i find these torque wrench settings;
axle shaft flange bolts 25Nm
differential carrier to axle housing 41Nm
carrier bearing cap bolts 69Nm
Old 25-02-2008, 12:09 AM   #4
oysta
I have those too plus more from the Ford manual but they're not for the oarts im interested in.
Old 25-02-2008, 08:38 AM   #5
whooligan
whooligan's Avatar
Disregard the torque setting in the manuals if your u-bolt look a bit dodgy. I sold a guy all my spare u-bolts and he snapped all 3 sets because he insisted on achieving the torque setting in the manual....You'd think you'd learn after breaking the second set. : Obviously after 30 years the original u-bolts aren't up to it, so just tighten them to a reasonable level. I've replaced diffs contless times and I've never had one come loose and my old RS used to give them a good old pounding.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2008, 01:16 PM   #6
aviper4u
fair enough point as set above
