Had a few hours spare today so decided to have a go at making a spacer for the airbox in the XR5. For those of you who don’t know the ECU actually sits in the airbox and all but covers the inlet horn. Why they put it where they did is anybody’s guess but it really does mess with the airflow and reports from some manufacturers of these spacers is that this modification is good for around 12 -14 hp in the upper rev range.
So, with a few hours to kill here is what happened; First up removed all the bits, ![]() It’s a bit hard to describe but the cooling fins on the back of the ECU actually penetrate into the airbox about 10ml, which puts them almost right on top of the air horn!! Not good for smooth air flow. ![]() This is inside the CAI tube, again not a good design for efficient air flow. ![]() First step was to make a template, first one made of cardboard to get the basic shape, than a more accurate one made from 4ml MDF ![]() Final fitting and some trimming had it close enough to use as a final template ![]() The spacer material I used was just an old nylon chopping board, cheap and easy to work with and more than suitable as a trial spacer. I glued 2 pieces together to finish up with a 14ml spacer. ![]() Installed and ready to go ![]() So what’s it like with the spacer fitted? Well it’s no different to drive around normally and 90% of the time you would not know it was there, but! There is a definite improvement in the upper rev range, not sure how much more power it makes (I’ll run it up on the dyno in the next few days) but it is much more willing to rev infact its now has a noticeable ‘kick’ from about 4800 and will spin through to 6500 quite willingly now, where as before it felt labored if you pushed it much past 5000. Having seen the original setup first hand I’m not surprised its made a difference, the factory setup really was very restrictive. I’ll get my son to draw it in autocad and I’ll have a few made out of 12ml alloy plate so if anybody is interested let me know. PS, some people suggest that its put there (in the inlet airflow) to keep it cool, well I gave mine a ‘pretty good’ work out with everything that I could think of ‘switched’ on and after some adrenalin charged driving I pulled up and popped the bonnet and the ecu was hardly warm so I don’t subscribe to that theory. Only down side is the ECU cover won’t go back on (just) so I’m hoping that using a 12ml spacer rather than 14ml may actually give me enough room to get it back on. Cheers. |
Now XR5hatch!
Sounds good mate.
Let me know if you do go ahead with the alloy spacers, I'll pick one up for sure. The prices for a spacer from the uk are ridiculous. I too was thinking to make my own but was trying to find a suitable material, never thought of a chopping board. While you were there did you find a way to run a larger diameter intake pipe to the standard airbox? I haven't had mine apart yet, but would like to retain the standard airbox if possible without going the full CAI route. I know BMC make just the carbon reinforced intake extension pipe (flexible) with a bell end to place in the grille or air-dam, I was thinking of mating one of these to the stock airbox? |
PERTHXR6T
Well done Paulie......Ours is going on the dyno tomorrow as it is getting a custom zorst put on. I already have this mod so it will be interesting to see if it has made a difference as we are getting a before dyno and after dyno once the zorst goes on.
As far as i know the only reason the Mondeo doesn't have the same power as the Focus XR5 is because of the zorst.
Rapid 327rwkw Typhoon MK2 05 ( Sold ) Panther Black XR5T Mondeo Sunroof BlueTooth Mods So Far Air Box Mod Lowered Eibach Springs 25mm Alloy foot Pedals Waiting for the Edit to come Custom Cat Back Zorst |
#4 | |||
XR5 convert
Just curious on this mod, do all the XR5's have a 'cover' over the ECU? Mine looks different to the photo. The ECU is not visible, there is as I said a 'cover' over this area. Had we stumped when I first looked under the bonnet for the unit. I couldn't see it anywhere.
'07 Mondeo XR5 aka The Valkyrie The mods: Window tint | Fomoco alloy pedals | Red painted brake calipers | THB Bury bluetooth | Bluefin | GGR CAI | Bilstein B6 sports dampers | Eilbach lowered coils | 2XS Inhaler (Top Induction Pipe) | EBC Ultimax discs and EBC red stuff brake pads | Mongoose 3" dump with Mongoose 3" 200 cell cat into custom system with Varex mufflers | Forge re-circ valve | Airtech intercooler coming soon
Now XR5hatch!
Yeah we all have the cover.
That photo is with the cover removed. The place to look is the right hand side of the airbox. |
#6 | |||
XR5 convert
Thanks for clearing that up.
