Old 25-05-2008, 10:43 AM   #1
mariajosie
Talking New Mondeo TDCi
Hello!
I am picking up my new mondeo TDCi on Saturday in thunder with bluetooth, leather seats and sunroof.
My question is I have an ipod, how do you connect the ipod into the sound system. What do I need! any connections!
Thanks for your help! :
mariajosie is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2008, 09:48 PM   #2
jared79
Sock Puppets
jared79's Avatar
Ok, I use my iPod in my Mondeo. It's very simple, all you need is a cable. Male headphone 3.5mm to male headphone 3.5mm. Plug it the head phone jack on your iPod and then in to the AUX jack in the glovebox. Now you may find the volume low, so I turn my up all the way and you have to turn up the volume stereo usually to about 15-20. Don't forget to turn down the volume when going to the CD or radio.
I have purchased a iPod radio transmitter which is a cradle and charges the iPod. So I plug it into the AC plug in the dash, it holds my iPod so I have easy access to it and it charges it at the same time. I just don't use the fm transmitter. Works great.
You can still close the glove box even with the cable plugged in.
Something like this is what I use.
http://cgi.ebay.com.au/New-3-in-1-Ca...QQcmdZViewItem
It works better than just sticking it in the glove box.
Hope that helps.
Oh and don't forget to set the EQ. It will sound better.
Ford Mondeo Zetec Hatch in Blue Ambition
jared79 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 11:39 AM   #3
mariajosie
Hope that helps.
Thank you so much for your help!
Old 26-05-2008, 07:32 PM   #4
monkeyboy666
monkeyboy666's Avatar
Has anyone with an ipod and bluetooth equipped Mondeo tried out one of those ipod bluetooth adaptors you can get, such as:
http://www.mrgadget.com.au/2006/12/j...h-adapter.html
I have a non-ipod mp3 player so it won't work for me, but from what I can figure out you should be able to plug the adaptor into your ipod and play it through your stereo, without the need for the annoying cable hanging out the glovebox?
Just wondering! (No responsiblity taken if you get one and it DOESN't do this!! )
monkeyboy666 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 08:40 PM   #5
jared79
Sock Puppets
jared79's Avatar
Maybe ok, but you will loose audio quality with one of those. And I am pretty sure that the Mondeo would not work with it as it would need to have A2DP which lets you play Stereo music through bluetooth.
Old 26-05-2008, 09:59 PM   #6
monkeyboy666
Hi Jared,
So theres an even LOWER audio quality than mp3...?!
And what is this A2DP of which you speak - wasn't he in Star Wars?
Old 27-05-2008, 07:47 PM   #7
jared79
Sock Puppets
jared79's Avatar
MP3 can be high quality, it depends on what bit rate you rip the songs at. I rip all my music at 256kb, so it's pretty much the same as a CD. You would be hard pressed in hearing the difference. They just take up more space on my iPod.
As for A2DP, it's just technology that allows a device to stream stereo music to another. But the Mondeo's don't have it, so you can't do it. Your better off to just plug it in.
Old 11-06-2008, 04:57 PM   #8
jared79
Sock Puppets
jared79's Avatar
Hey mariajosie, I have a photo of my iPod setup.
Old 11-06-2008, 06:38 PM   #9
scribbly
You live in Brisbane and have the temp set to 24. It must be colder than I thought. :togo:
MA Mondeo
SZ Territory Titanium - >400,000 km
VF SSV Redline
BiTurbo Ranger XLT
scribbly is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2008, 07:06 PM   #10
mariajosie
Thank you for that picture! I have purchase everything for my ipod now I have to try it out in the car!
thanks
Old 11-06-2008, 07:23 PM   #11
LRsedan
Now XR5hatch!
LRsedan's Avatar
I can't get enough volume using my Ipod.
I find you have the HU cranked nearly all the way up if you want moderately loud music.
Also if you turn up the iPod volume the quality degrades :(
LRsedan is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2008, 08:07 PM   #12
apstar
apstar's Avatar
You could try one of these devices it sees the Ipod as a FM station which should give you better volume
http://www.dse.com.au/cgi-bin/dse.st...ct/View/XH8217
apstar
apstar is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2008, 10:35 PM   #13
jared79
Sock Puppets
jared79's Avatar
apstar
The one I use is a FM transmitter, however, the audio quality is far worse than the AUX input, so I only use for charging and as a cradle. Plus if you are in a city, you will find that you will get a lot of interference from other stations. It's true about the volume. You do have to crank it. But you can get enough volume. I find that between 15-20 on the volume is best.
Another option is this
http://catalog.belkin.com/IWCatProdu...duct_Id=156032
It will charge your iPod and is also an amplifier, so you can get more volume from your iPod. I haven't used one and I had a friend that used one in is Honda CRV, he said he got engine noise through the audio. But I think his car had issues. So I can't be sure if they will work or not. But it would be a solution. I just turn up the volume and I am fine with that.
Old 12-06-2008, 12:23 AM   #14
apstar
apstar's Avatar
yeh can see problems as you said I think the frequency is set at around 88Mhz the other one I have used is the cassette adaptor
http://www.dse.com.au/cgi-bin/dse.st...uct/View/C9216
not sure if the Mondeo has a cassette player!!!
apstar
Old 12-06-2008, 11:17 AM   #15
mondeoxr5
I run through the aux on mine and don't have any problems with volume or quality.
And when I bought my car the dealer found a company in the UK whcih specialises in making ipod integration kits. They then found out that they were making one for the new mondeo so it would be contolled from the steering wheel and display song infromation through the convers+ display. It also charges the ipod at the same time.
They have ordered one for me and it should hopefully show up in the next couple of weeks (once they actually release it). Once it is installed I will post photos and post on how good it is.
mondeoxr5 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2008, 03:04 PM   #16
TheColonel
TheColonel's Avatar
Something like this i assume: http://www.ipodcarkitdirect.co.uk/iP...nk_Gateway_100
2008 Ford Mondeo XR5 Turbo - Panther Black
Airbox Plate Mod + BMC Panel Filter
TheColonel is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2008, 04:13 PM   #17
mondeoxr5
fairly similar I think
From what I understand after it is installed you plug your ipod into a dock down by the cigarette lighter. Song information is displayed on the convers+ display and you can control it from the sterring wheel.
It is made by these people
www.connects2.com
Old 12-06-2008, 05:01 PM   #18
jared79
Sock Puppets
jared79's Avatar
That is awesome news, can you please find out what the model of the kit is? I am very interested.
Cheers.
Old 12-06-2008, 05:16 PM   #19
Lord Viykor
XR5 convert
Lord Viykor's Avatar
Cheers.
+1 I'm interested in finding out more as well.
'07 Mondeo XR5 aka The Valkyrie
The mods: Window tint | Fomoco alloy pedals | Red painted brake calipers | THB Bury bluetooth | Bluefin | GGR CAI | Bilstein B6 sports dampers | Eilbach lowered coils | 2XS Inhaler (Top Induction Pipe) | EBC Ultimax discs and EBC red stuff brake pads | Mongoose 3" dump with Mongoose 3" 200 cell cat into custom system with Varex mufflers | Forge re-circ valve | Airtech intercooler coming soon
Lord Viykor is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2008, 08:55 PM   #20
TheColonel
TheColonel's Avatar
Ditto here
Old 12-06-2008, 09:14 PM   #21
jared79
Sock Puppets
jared79's Avatar
Hope is works with the iPhone too.
Old 12-06-2008, 09:17 PM   #22
buts44
Me three!
Black XR5 Turbo
buts44 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2008, 09:21 PM   #23
LRsedan
Now XR5hatch!
LRsedan's Avatar
yes more info, very interested.
The Harman Kardon Drive + play is also another option which works well.
Old 12-06-2008, 11:10 PM   #24
mondeoxr5
Sorry I don't have more info on it, as far as I am aware it hasn't even been released as of yet. I do not know how my dealer set it up, but I cant wait because having to change the songs through the ipod controls is a pain.
I will do a detailed post once I have it installed, which will include where it came from and the model number.
Old 12-06-2008, 11:14 PM   #25
jared79
Sock Puppets
jared79's Avatar
Thanks Mondeoxr5
Old 13-06-2008, 09:33 AM   #26
Dusty1
Giddy up!
Dusty1's Avatar
I'm keen too on this adaptor thingo. Will it work on cars without the flash-o XR5 display? That sounds like a fair chunk of people on here. Would be great, as i hate the AUX line that comes up on the display, on the stereo and between the dials.
Current:
June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint.
Nov 10 built XR6 Sensation.
Previous:
Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof.
Dusty1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2008, 10:03 AM   #27
mondeoxr5
my understanding is that it will work on any new mondeo. On the XR5 it displays on the radio and the convers+. On any other model just through the radio.
Old 13-06-2008, 12:26 PM   #28
jared79
Sock Puppets
jared79's Avatar
Just the radio is fine. Just want control.
Old 17-07-2008, 12:39 PM   #29
Zippy7
Just wondering if there is there any update on this iPod integration kit...
Mondeo XR5, Thunder.
Zippy7 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2008, 03:42 PM   #30
apstar
apstar's Avatar
Maybe I'm getting too old but why go to all of this trouble when a CD is 650MB in capacity and the average sample rate for Ipod is 128k per song and allow 3 Mb per Mp3 so you have over 216,666 Mp3's on a cd with the ability to do folders am I missing something!!
apstar
