25-03-2009, 10:23 PM | #1 | ||
we have the volvo conversion brakes on my escort which is also on mk2 1600 struts and hubs. problem is is that the tie rod ends off the mk1 or too sloppy in the hole on the wheel hub. the mk2 ones fit perfct but wont screw into the rack ends. how have people gotten around this problem previously.
can the mk2 rack ends be put onto a mk1 rack?
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
25-03-2009, 10:37 PM | #2 | ||
you need to either use a MK2 steering rack, or get some 'Green' tie rod ends.
see link below, goto steering section on the left. http://www.smckaperformance.com.au/
1977 MkII Escort Ghia. 2006 MY07 Subaru Liberty GT Spec B wagon. my photo blog; http://www.jamesruff.net |
26-03-2009, 09:28 AM | #3 | ||
Ute Forum Moderator
Something deep in my memory tells me Mk1 used imperial dimensions and Mk2 metric - would this be right?
26-03-2009, 05:15 PM | #4 | ||
mk2 is a coarse thread at the rack and mk1 is fine
26-03-2009, 05:17 PM | #5 | |||
from smcka
26-03-2009, 06:01 PM | #6 | |||
sorry. got mixed up. :
26-03-2009, 07:40 PM | #7 | ||
i cant be the only one to ever have this problem so there would be a quick fix i hope
26-03-2009, 08:53 PM | #8 | ||
74 mk1 2 door escort:
will a mk 2 rack fit and replace the mk1?
26-03-2009, 09:21 PM | #9 | ||
checking with smcka now anyway. dont want to put a mk2 rack in it
30-03-2009, 11:13 PM | #10 | |||
I'm doing the opposite. Fitting Capri struts in my Mk 2, so I'm swapping the Mk 2 rack for a Mk 1 rack. Green tie rod ends are usually the way around this problem, but if you need to replace them in a hurry, you can't just go into autobarn and buy a new set off the shelf. Stupid wheel alighnment guys tend to get a bit sloppy with the hammer every now and again and they insist on replacing tie rod ends. Swapping the rack keeps it simple and cheaper in the long run. |
31-03-2009, 07:59 PM | #11 | ||
can you change the rack ends?
01-04-2009, 01:16 PM | #12 | ||
Rally Nut
You can change the rack ends, but if your doing that you will need to keep doing that if you need to replace the rack at any stage
The easiest thing to do is to replace the Mk1 rack with a MK2 item that way you have a stock standard item in there Mk2 racks are a dim a dozen, i have thrown that many out its not funny, you can always upgrade to a quick rack - shop around $275 - $330 |
09-06-2010, 11:37 PM | #13 | ||
So the green tie rod end won't work when trying to marry MK2 struts to MK1 steering rack?? The item discription is a little confusing.
10-06-2010, 07:12 AM | #14 | ||
Rally Nut
NO the 'green' tie rod ends will work when fitting capri or MK1 struts to a MK2 escort
I just had the steering arms on my GP4 struts machined to suit MK2 tie rods |
