Old 16-04-2009, 11:08 AM   #1
Springfield_Johny
Springfield_Johny's Avatar
Default Thoughts on this product
Has anyone ever used this as a rust prevantitive? I remember seeing a show on the ABC a few years ago, they interviewed people who used the stuff commercially who raved about it both as a rust prevantive and lubricant for heavey machinery
http://www.lanotec.com.au/
Springfield_Johny is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 11:28 AM   #2
want-a-XY
want-a-XY's Avatar
i think dad and i used it on the rollers for his boat trailer. if not a very simlar product. seems to work pretty well
want-a-XY is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 11:30 AM   #3
Springfield_Johny
I'm more concerned about the rust prevention side of things in hard to get to places so I only have to do rust work once
Old 16-04-2009, 07:57 PM   #4
gregaust
I've always stuck to fisholene 1st to run into the crevices the follow up with Tectyl . Tectyl is a proven product and lasts many years .
I have seen that stuff you mentioned and curious myself on how good it is .
Sort of like still deciding iif POR15 is necessary or if a rust converter followed by fish oil and tectyl is just as good .
Old 16-04-2009, 08:07 PM   #5
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Lanolin products are performing remarkably well.
A company which operates ferries from Port of Bris to Moreton Island have saved huge expenses in fuel using lanolin products as an anti fouling on their ferries ( fast Cats).
Lanolin is an excellent, anti-fouling, penetrene, anti-friction, anti rust product.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is online now   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 08:14 PM   #6
richa
handsomest man in showbiz
richa's Avatar
Red face Does it work?
Maybye,maybye not....though i've never seen a rusty sheep
What kind of rat bastard psychotic would play that song right now...at this moment?.............
R.I.P. Dr Thompson...
'72 GS
richa is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 08:48 PM   #7
Silver Ghia
Silver Ghia's Avatar
You've got the right idea with the Fishoilene then Tectyl 506. I can vouch such a system does work well even in temperature extremes and high speed airflows after using it for many many years on aircraft internal and external surfaces, also my cars.
POR15 is different, its a system that neutralises the corrosion, then seals it all off with a hard coating that prevents moisture and air getting to the affected metal surface. You use it if you want to do a more permanent fix, but you need to be able to get to the corroded surfaces so you can clean off the surfaces before applying the corrosion preventative paint.
I have heard of the Lanolin based corrosion preventative compounds and people have raved about it, but have never used it myself. Read Burnedouts post above ^^^^which says its good.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 09:51 PM   #8
dave351cid
playing in my big shed
dave351cid's Avatar
i have used a few different lanolin products myself. seem to do their job very well.
a few years back when i was in the auto rust proofing business i did some experiments by grinding the surface coating off new mild steel plates and painting them with different rust prevention products. i had several different professional type products , ie: wurths, wax gard, endrust, shield 21, nil rust, protection australia and some others that i forget their names now. i also did a sample using just lanolin liquid and left them hanging on the back fence at maroochydore for 6 months.
i was surprised to find that out of all the products, the 3 that seemed to work best were wurths yellow wax (used by mercedes etc), waxgard ( now owned by the same lot that own ming) and the lanolin.
some of the name products performed rather sadly.
the lanolin is very good for getting into body joints and tight spots. it can be a bit messy when it runs out the bleed holes but that is a worthy compromise for knowing that its getting into those difficult spots.
we use a lot of lanolin grease at work now building power lines, both as corosion protection and as an electrical connection aid.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 11:04 PM   #9
nfury8
Default Use an electronic rust stop
Hey there, i had an older 4wd for 8 years prior to finding my toy, the 4wd had small amounts of rust in it when i got it so had it repaired/resprayed and installed a product called RUST STOP. They use sacrificial anodes and some elctronic wizardry, anyways never ever had any rust return or show up and believe me I WAS SURPRISED that it worked, but it really did.
Grab one from supercheap for cheap insurance.
http://www.ruststoponline.com/index....=119&Itemid=77
nfury8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 11:14 PM   #10
kempster1
Great stuff Lanotec
I have been using it for about 5 years and it is great.
I sprayed my boat trailer with it on the first day, I use my boat every week end and it still looks perfect.
I work in the electrical supply industry, we spray everything with it and it makes life very easy.
The grease is also great stuff
kempster1 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2009, 12:32 AM   #11
richa
richa's Avatar
Smile Lame 'Comic Relief
Originally Posted by richa
Maybe,maybe not....though i've never seen a rusty sheep
Sorry 'bout that...not much help really...
'72 GS
Old 17-04-2009, 09:23 AM   #12
ebxr8240
Performance moderator
ebxr8240's Avatar
Not too many bald sheep either.. Ewe !!....
Daily driver GTE FG..
Old 17-04-2009, 10:03 AM   #13
bcr2734
Off tap Truckie
bcr2734's Avatar
I have used it on my Mk1 Gt years ago when it cam out. A mate got a tin for free from a rep. 10years later it is good still. But check out other product out now and they may have inproved. Also my T3 has lanotec in it too now
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
: Another Power Installment Soon :
1968 KC Bedford
1970 Mk1 Escort GT
1980 Mack Superliner 120t: Project Puppy Dog!
AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5
bcr2734 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2009, 10:14 AM   #14
flappist
When I had my gun shop, the trawler operators used it to stop their rifles and handguns rusting at sea. It worked extremely well, in fact it would preveny rust on blued guns while "stainless steel" ones that were untreated started to spot.
