Old 19-04-2009, 01:17 AM   #1
Tiapan
XF 393 3v CHI heads
Tiapan's Avatar
Default Engine weakness
I thought i would start this thread to share differant findings or popular knowledge about differant engines and there factory weaknesses, when modded or not, its interesting to know and is also great pub ammo
may also help correct many beliefs or rumours
ill start...
Boss 5.4's sintered metal oil pump gears, fail with high rpm or hp, need billet oilpump gears
Nissan SR20, rocker arms jump off the lifter in high rpm applications, need to use rocker arm stoppers
Cleveland, oiling system can starve the bottom end, can be corrected with oil restrictor kit,
core shift in many blocks
Windsor 302 - prone to splitting due to thin webbing, aftermarket blocks have corrected this.
Boxer - cracking piston skirts in stock application when being thrashed in cool weather
Holden v8- might be quicker to list the pro's? lifter bore alighnment to cam, always on the , needs brass lifter bores installed
Holden 202- Shreading cam gear when pushed too hard
ill add more later, see what you can thing of
XF Falcon, 393 Clevo. 11.01@123mph
"RAZNREVNU"
Tiapan is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 02:36 AM   #2
Falc'man
You dig, we stick!
Falc'man's Avatar
Here's info on the ticking problems with the pre '05 Boss.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 08:10 AM   #3
CAMS290
trying to get a leg over
CAMS290's Avatar
Punching pushrods through rocker arms, wearing camshafts out because of lack of oil on lobes, factory single row timing chains stretching or even breaking.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 09:29 AM   #4
66 coupe
around the place
66 coupe's Avatar
thats only when they have oil pressure, usually the pickup is all sludged up = no oil pressure
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 11:06 AM   #5
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
5.4 boss motors prone to ovaling bores.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 11:28 AM   #6
Dezza
Parts bin special
Dezza's Avatar
3.9/4.0 litre straight 6, particularly in EA-EL - prone to blowing headgaskets - Everyone know EAs blow them, but not everyone know EB-ELs are just as bad for it.
Old 19-04-2009, 02:03 PM   #7
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
BA XR6T - Rods & Valve Springs. Prone to throw the leg when pushed.
VN-VR Buick 6 - dare comment?
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 03:10 PM   #8
bcr2734
Off tap Truckie
bcr2734's Avatar
yes they do, Every mechanic i know does aswell as do the owners.
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
: Another Power Installment Soon :
1968 KC Bedford
1970 Mk1 Escort GT
1980 Mack Superliner 120t: Project Puppy Dog!
AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5
bcr2734 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 03:15 PM   #9
Dezza
Parts bin special
Dezza's Avatar
But the consensus I get from some people is that EAs blow head gaskets every few 1000kms but EBs are perfect. I know most know the real story, but some don't and are just oblivious to the fact they're pretty much the same engine.
Old 19-04-2009, 07:43 PM   #10
yift
dezza they are bad ea-bf. ba/bf not as bad but still prone. no ford ohc motor is safe from this kind of weakness.
Old 19-04-2009, 07:47 PM   #11
stevepet
Nissan TB42 prone to cracking heads especially if using LPG.
stevepet is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 07:58 PM   #12
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah I don't think so mate. I looked after a fleet of cabs and we never, ever took a head off an AU. Each of the 20 odd cabs did half a mil each while i looked after them too. The AU head gasket is a steel one as opposed to the paper one found on the e-series. The reason they blow is because of an iron block and alloy head, and the steel head gasket avoids this problem.
Old 19-04-2009, 08:02 PM   #13
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Got a link?
Never heard of that one before, Cast Iron modular blocks are usable up to 1200rwhp without issue. The only thing that kills a 5.4L mod block is the connecting rod coming through the side with factory sintered rods at 6500rpm+
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 08:04 PM   #14
CAT600
CAT600's Avatar
There are 600+ rwkw XR6T/F6's out there using stock heads/head bolts and blocks. There are 400+ rwkw ones still using stock head gaskets as well.
Daniel
Old 19-04-2009, 08:05 PM   #15
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
The biggest issue with a cleveland is getting the valvtrain/geometry correct for any high rpm work, by far the most common cause of breakages, IMO the oiling issues are over rated, and easily fixed with a well designed sump..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 08:31 PM   #16
Windsor220
Now Fordless
Windsor220's Avatar
I thought EF-ELs were the worst actually.
Old 19-04-2009, 09:05 PM   #17
madmelon
The Holden/Buick 3.8's tend to stretch timing chains over time (more than most cars anyway), causing the cam timing to get progressively worse. Results in poor performance and economy. Can't recall the source of this information.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 09:18 PM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
Holden 3.8 V6's tend to be so rough they cause brain damage to their drivers.
Old 19-04-2009, 09:23 PM   #19
CAT600
CAT600's Avatar
Holden Ecotec's tend to be rough, Their drivers are brain damaged.............
Thats a paradox :
Old 19-04-2009, 09:24 PM   #20
Mr Hardware
I hate the holden slagging but this one made me mega LOL
Old 19-04-2009, 09:28 PM   #21
BJ
Yep i'll second that one Tony.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 10:23 PM   #22
needaXYGT
AU II XR8
needaXYGT's Avatar
EA-EL all the same!
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 10:44 PM   #23
yift
how often do cabs sit around switched off for more than 3 hours? head gaskets on these sixes blow because of the cooling off diferences between iron and aluminium. steel gaskets do help but cabs should never be competed with private vehicles or used as a real world example. i have seen taxi autos last 300,000+ km before needing replacement whereas a 4speeder in a private car like mine or yours may only last 150,000km. i have done a few headgaskets on the ohc motorsea - el are by far the worst but like i said no ohc motor is safe.
Old 19-04-2009, 10:46 PM   #24
Dezza
Parts bin special
Dezza's Avatar
True. My uncle's EL did about 3 of them, and it's done roughly as many kms as my EA which has only done one.
Old 19-04-2009, 10:47 PM   #25
yift
Originally Posted by CAT600
Got a link?
Daniel
that was an issue with the early 5.4's when ford did a recall for supposed piston rings. no links for this info, just a ford engineer who i know.
Old 19-04-2009, 10:51 PM   #26
yift
Daniel
like i said ba/bf not as bad but still prone.
another thing i forgot to mention was early barra sixes cracked their blocks too. most ford dealers, that had these failures come through, thought it was a headgasket problem when infact is was cracked blocks. it had something to do with the casting of the early blocks from memory but cant remeber 100%.
Old 19-04-2009, 10:59 PM   #27
yift
mitsubishi v6: burn valves, wear lifters
mitsubishi magna 2.6 astron motors: timing chain stretches (bloody noisey)
toyota 4 cyl motors: carboning of oil internally in the motor.
daewoo motors: same as above, chew out cam lobes
ford laser kc ke/mazda 323 same era: head gasket, cam bearings
chrysler motors:
ls1: piston slap from early motors due to poor casting
pre ecotec v6 motors: what isnt wrong with them
ecotec motors: as above but improved
alloytech motor: same as above but worse and less power, stretch timing chains especially in the VE commodore.
Old 19-04-2009, 11:04 PM   #28
CAT600
CAT600's Avatar
If there was ever an ovality issue with 5.4L blocks, I have never read about it, and it would be an issue that was present when the block was machined from new....... those blocks just dont give any trouble at all.
If you said piston ring pack issue, well, we all know that the early 290 engines had a problem with the combination of Mobil 1 and FPV's ring pack choice.
Daniel
Old 19-04-2009, 11:19 PM   #29
svo347
AFF's 1st DM.......
svo347's Avatar
Im sure im goin to get trampled here but i thought the idea with Clevo oiling systems was to add a restrictor kit to limit the volume of oil pumped into the heads at high rpm and the oils slow return to the sump. I remember seeing breathers extended up fairly high in a mates sprint car engine as everytime he went around the track, oil used to spew from the right hand r/cover, restrictor kit fitted and it was all good
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 19-04-2009, 11:21 PM   #30
CAT600
CAT600's Avatar
I can only assume that the bigger and better baffled sump must prevent oil starvation due mainly to the extra volume?
Daniel
