Old 06-08-2009, 10:48 PM   #1
sweetswan
Default mk 2 struts
Hey everyone. Hope somebody can help me out. I have a 1980 mk2 Panelvan, 1600 4 speed. The front struts are stuffed and wanted to know are all mk2 struts the same? Can you put 2L struts in, if its a 1600? I undid the bolts and the hole diameter is 11mm and its 95mm from the centre of 1 hole across to another. Do other struts have the same measurements? Is it possible to have them over-hauled?
cheers
sweetswan is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2009, 11:10 PM   #2
krt10
eskyman
krt10's Avatar
yes there is a difference
1.6 struts have a 49mm diameter strut tube,
2.0 struts have a 51mm diameter strut tube.
the 2lt struts also have a larger spring platform
2lt struts will fit a 1600.
who says kents cant be quick
krt10 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2009, 08:59 PM   #3
Les
Mk2 Racer
Les's Avatar
I have swapped struts over but the 2 Ltr are 100mm longer and stronger so will sit the front up a bit higher.
I have a Mk2 1600 PV in the yard with good struts if you can't find anything locally, I'm in Whyalla SA but freight is easy to arrange.
Les is offline   Reply With Quote Multi-Quote with this Post
