what have people done with electronic ignition for 1300/1600 kent motors?... is there a kit? or a trick?
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
Hi,
I'm not sure about the Kent motors Specificly, however i've used a Pertonix Ignitor Kit on my Corty before i went to a Crane Cams Hi-6 and was very impressed with it it uses a magnetic pick up so there's no contact or light diodes, it was really easy to set up and the best thing was no more points or timing adjustment =D. This is there website: http://www.pertronix.com.au/ I think there about 120ish last time i checked, The best thing is that you just fit it to your existing distributor and thats it, there's only 1 extra wire that connects to the Positive on your coil so it takes about 20minutes to install it all and tune it up. Hope this helped Cheers Jason
Current Project: Rebuilding my Corty! 220kw Au3 XR8 Engine, full Custom Zorst, EMS Computer, Underdrive pulleys and MSD coil Parks. TKO Tremec 5 Speed Full Floater 9in 31 Spine with locker Its almost there!!!! |
Good link there as Aldon was the distributor until they folded. The systems are the same - just a different name. I have an Aldon ignitor in the Mini and it is the bees knees(driving through driving rain, no dizzy shroud and not a hint of water shorts...it just keeps on going)
Pertronix will be a good choice... |
#4 | |||
V8's for ever
