Old 19-01-2010, 01:24 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default 1000kw XH XR8 Ute
Insane.........
(998 rwhp = approx 1000 engine kW's)
Youtube linky CLICK HERE
XR8 This ute is a Tickford XR8. Mods consist of, Koni struts and rear shocks, Lovell front coils and reset rear leaves, 17" American racing rims with Dunlop Tyres, EL GT bonnet spoiler, mods to front spoiler to fit intercooler, custom hand made sail plane, hard tarp, tray mounted battery box, 4 sub speaker box mounted in tray though to cab.
XR8 Engine has gone through several stages, starting from a sportsman SVO block running 500rwhp using a T Trim Vortech and going through a step by step process as owner required more and more horse power. Along the way every system that had been built for the original 500kw combo was upgraded, inc intake, blower, fuel, engine , exhaust, ignition, management, ending up with a Torque plate honed full machined and prepped DART block, 347 Summit crank, Eagle rods, JE pistons and rings, Copper head gaskets, Edelbrock ported and polished heads, Trickflow intake manifold, 80mm Holley throttle body, Girdle mounted Jessle roller rockers, Custom Comp Cam roller cam and Crower lifters, ARP stud kit, High Energy sump and Felpro gasket, Mellings oil pump with ARP drive, Romac balancer and Rollmaster Chain set. The Super charger system consists of a MWS Custom Vortech bracket, V7 SYI Compressor, Air assist, Custom Gilmore drive, Vortech crank brace, custom velocity stack, Mondo unloader valve, Custom twin intercooler core, custom SS 3.5" plumbing. This is all finished off with a twin 3.5" mandrill SS exhaust system, the system starts with a pair of custom 1 7/8" Headers that plumb to twin 4" high flow Cats, for volume control there is a pair of custom large mufflers and to finish we have twin 3.5" tail pipes. Management is done with Wolf 5D. also as can be seen by the pic's there where several stages of the ignition system to try to get to the 1000rwhp figure that this car has know attained. Below are some pic's we got along the way.
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 06:52 PM   #2
whiteELXR6
whiteELXR6's Avatar
What's the story with the air intake setup on the blower. Does he run that all the time or only for dyno runs. Reason I ask is I have clearance issues with my blower setup (procharger) and this looks like it would be a suitable solution.
MY RIDES
1995 DF LTD-the weekender
1999 Holden Rodeo-the daily
2007 Kenworth T401 Tipper-the road builder
whiteELXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 07:13 PM   #3
Sorted
Sorted's Avatar
Here is a better pic of the intake for road use
different set up but CAI is unchanged
Tuned by DYNOMOTIVE
Old 19-01-2010, 09:04 PM   #4
mickyyyy
Its a wicked ute but im suprised that it uses a Delco 808 ecu from a VN 5L to control it, i would of thought they would of used something abit more exotic, but in this article u have it says it has a Wolf D5 which im sure it dosent.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 09:10 PM   #5
Windsor220
Now Fordless
Windsor220's Avatar
This is a Motorvation regular. Power output is always rising.
Old 19-01-2010, 10:10 PM   #6
JAZSXY
Parts Fiend
JAZSXY's Avatar
Anyone know what brand of hardlid that is?
Successful Sales With
frenzal56, falconxr, loosecannon, lima_been, bo5ton, Mardk, Chapter Four, leakey, POELWYK, Dman4.0, rayban76, tutor, PridenJoy, Aplito Futura, sbutler, Bosko, storta1, portokatsiki, AUte, 5.8, xxxg, FTW-302, LeadFoot81, Peuty, BillM, Sox, needfordspeed, watejs06, CATXR8
JAZSXY is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2010, 09:02 AM   #7
Sorted
Sorted's Avatar
here is the linky - the car has used various engine management systems chasing more power each time http://www.marksworkshop.com.au/Pages/feature/xr8a.htm
XR8 Fuel system The first 4 shots are of the oridinal fuel system designed for 500kw this fuel system consists of SX pump, SX filter, Paxton fuel pressure regulator, Vortech billet fuel rails and 50 lb Rochester injectors. This is all plumbed together with stainless steal form line, braided line and speed flow connectors.
The next 3 shots are of the 1000kw fuel system including to more pumps an extra swirl pot with breather can and up front some 1000cc injectors. Also in there is an methanol injection tank, pump and regulator.
Tuned by DYNOMOTIVE
Old 21-01-2010, 05:04 PM   #8
DJMaRV
HardTrance an HardStyle
DJMaRV's Avatar
thats an ultimate weapon...an looks bit of a sleeper....WOW!...
looks like the front tire is a little flat tho?....
'04 BA Xr6T
42lb
12psi
HDi Intercooled
TurboSmart
Earls Filter
PBR Brakes
Warlbro
DJMaRV is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2010, 05:26 PM   #9
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Supporting the weight of all those horses, I'm not surprised it looks flat.
It's probably just scared.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2010, 06:36 PM   #10
Iggypoppin'
Chasing a FORD project!
Iggypoppin''s Avatar
does he use slicks or something wider to hold that power down? I imagine those rears(unless my eyes are playing tricks) are a bit skinny and would just break traction constantly. Looks the goods though, too much want!
Originally Posted by HSE2
Today we might get beaten at some of our own game. Tomorrow we reinvent it.
Game. Reinvented.
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon.
Iggypoppin' is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 10:33 PM   #11
JAZSXY
Parts Fiend
JAZSXY's Avatar
Website for this thing? Or any info on the hardlid?
Old 25-01-2010, 04:54 PM   #12
DJMaRV
DJMaRV's Avatar
hahahaha...yea i guess, it might be afraid of hieghts too.....
'04 BA Xr6T
42lb
12psi
HDi Intercooled
TurboSmart
Earls Filter
PBR Brakes
Warlbro
Old 26-01-2010, 09:50 PM   #13
BPXR6T
I was thinking sleeper until I heard it run
Old 27-01-2010, 08:51 AM   #14
Sorted
Sorted's Avatar
Website www.marksworkshop.com.au
Tuned by DYNOMOTIVE
Old 01-03-2010, 10:58 AM   #15
Scaffy
Rlegaur Mbemer
I'm not sure when that article was last updated, but I'm 99% sure I saw a dyno sheet on the windscreen at motorvation that was 1008rwhp or something like that.
I don't think this gets driven on the street much. He lives out in the wheatbelt and has a blown BA XR8 for his normal driving duties, I believe.
I don't think it's even been to the drags. Would be interested to hear how it went if it has.
[YEAH NAH] Red EL XR8 with Trick Flow top end kit, 70mm tb, 73mm maf, 24lb injectors, tweecer, 3.73s & tired T5 = 275rwhp & 13.155@105mph NA. 12.375@116.73 N2O - Off the road, awaiting 347 293ci and Astro Performance gear-kitted T5 (A5)
White EL Series II XR8, manual, high flow cats, single 3" exhaust and Quarterhorse = 236rwhp and 14.18@97.5mph - E7 heads FTW! - SOLD
Scaffy is offline   Reply With Quote Multi-Quote with this Post
