Old 01-02-2010, 09:26 AM   #1
Geobee
Default Ford Focus Stereo Locked
Hi all, would anyone be able to help with a focus stereo locked. customer put wrong code in several times, but now has correct code, but display shows locked. Is there a procedure, or does it have to go back to factory. Regards. Geoff
Geobee is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2010, 12:22 PM   #2
mrbaxr6t
mrbaxr6t's Avatar
I don't know the answer but it may help to know what model Focus you are referring to - had an old falcon one that did that and sorry to say but it bricked it - not even Ford could fix it, hope you sort it out
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2010, 01:18 PM   #3
somers181
somers181's Avatar
Hi, if all else fails ring Ford Customer Relationship Centre on 13 3673 (13 FORD) and they can advise but you need to know full vehicle details so have your warranty/service guide book with sticker in back ready as they will ask for details.....
Capri Car Club of NSW,
Keeping the Legend Alive since 1985
somers181 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 06:20 PM   #4
Geobee
Thanks both, will call ford asap. Regards. Geoff
Old 04-02-2010, 11:20 PM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
Another way is to take your registration papers to a Ford Dealer, who should be able to look up the code. They may (probably will?) charge you for this, or may need to remove the radio to find serial number, which they will also charge you for
Old 04-02-2010, 11:22 PM   #6
zetec
Zoom Zoom
zetec's Avatar
Failing taking it to the Ford experts (Dealer) then usually it's just a 24 hour wait.
Should even say on the display or in the manual.
2012 Mazda3 MPS
Old 11-02-2010, 10:34 AM   #7
sailaway
sailaway's Avatar
Try rebooting it completely! That is disconnect the battery. Then reconnect and try the correct code. :
Just a thought.
Pete
Melbourne
2010 Ford Mondeo Zetec TDCi Diesel
Colour: Frozen White
sailaway is offline   Reply With Quote Multi-Quote with this Post
