Old 12-03-2010, 07:44 PM   #1
rallyboy77
Default New Fiesta Pinging
Our Fiesta has just passed 1000kms! :
I noticed the engine occasionally pings even though its not laboring, has decent revs and not much throttle. I wouldn't expect this normally. Has anyone else noticed this?
rallyboy77 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 08:22 PM   #2
trento
Audiophile
trento's Avatar
Are you running it on 91RON/E10???
WS Fiesta in Moondust Silver ~ G2 17's (205/40/17), 1700W Sony stereo, SOLD
ZOOM ZOOM: 2009 Mazda 3 MPS (2nd gen) 256bhp through the front wheels... hello torque steer!!!
trento is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 09:09 PM   #3
robjh80
robjh80's Avatar
As trento said .. you need to run Premium Unleaded in Euro Cars like the Fiesta.
If your using standard unleaded that will cause the pinging.
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 09:41 PM   #4
GoesLikeAZetec
GoesLikeAZetec's Avatar
yep on 91 i noticed a little bit of pinging.. ive never had it since we started using 98
GoesLikeAZetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 09:44 PM   #5
trento
Audiophile
trento's Avatar
Even 95 is ok, although all the servos down here only have E10 and 98RON
Old 12-03-2010, 11:59 PM   #6
dannyhilton
dannyhilton's Avatar
As a previous 98RON supporter, I say use 95RON. Ford said it themselves, unless your car is tuned to run a high octane fuel, it's a waste to put it in. 98RON gives me no better economy, it's not smoother or faster and more expensive. 95RON is the minimum in the UK so run that I say. Works a treat.
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum
PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec
dannyhilton is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 10:18 AM   #7
vegabass
BASS ON BOARD!
vegabass's Avatar
What about intake temps? The hotter the temp the higher the ron needed to combat pinging. Remember in the UK its cold, hence the crap intake design, they simply don't need to much design in that area. Its not only the fiesta, I had a 97 MG-F which had a air-box in the engine bay as usual however the intake pipe to the box as about 30cm long and inside the engine with no access to outside air it was actually sitting over the exhaust. It was useless to drive on a hot day, that's until I made a CAI which transformed the car 100 fold.
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 08:10 PM   #8
Dustproof
Dustproof's Avatar
There is no problem, the WS Fiesta is in constant state of tuning. It often looks at how much Ignition advance and fuel the engine is using, occasionally it will give a pinging rattle and it goes away pretty quick. The new model Focus does the same thing, I asked Ford and they advise this is not damaging the engine.
Noel
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2010, 01:16 AM   #9
StrokedXT
my wifes sometimes pings, told her to start putting better fuel in it.
As mentioned only does it on hot days under heavy throttle in 2nd it pings its head off.
StrokedXT is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2010, 02:47 AM   #10
greenfoam
We just completed a 5000km trip in the Fiesta to QLD and back. There was a substantial difference in fuel economy depending on what fuel was put in it. Shell 95 seemed to be the good stuff in NSW, Caltex was the winner in Victoria. BP ultimate was rubbish on the tank of that we used, less power and used alot more fuel. We used about 6 tanks I think and you could often pick the difference between them after driving 700ks on one then filling up with a different fuel. Some were better than the last some worse. The tank in NSW with the shell 95 got a "wow" from my wife after the previous tank of BP ultimate. It's only had 91 octane in it once and it pinged. It says in the manual you need 95 anyway. Overall the maxxis tyres we have on the front now do use quite a bit more fuel than the oem hankooks. At 110 (gps) we were using 5.5l/100 and about 5.0 or high 4's at 100. Thats on good smooth roads. On more typical country roads it was using 5.4 ish at 100
greenfoam is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2010, 03:04 PM   #11
dannyhilton
How do you find the grip on the Maxxis tyres Greenfoam?
Old 20-03-2010, 03:25 AM   #12
greenfoam
The grip is good on them, pretty similar to the hankooks, They are a good tyre for the money but my wife has allready decided to go back with the hankooks or something with even a bit less rolling resistance. As she rightly says an extra 50 bucks for a tyre is nothing if you can save 10% on fuel
Old 20-03-2010, 12:29 PM   #13
Piotr
Non-Regular Member
1: The car is designed in GERMANY not the UK,
2: The car is designed for the global market not just the UK,
3: All cars are tested in BS conditions that 99.99% of consumers will never see (think cold starts in Siberia and heat testing in the Sahara)
2005 Renault Sport Megane 225
