06-06-2010, 02:25 PM | #1 | ||
Hey
I was thinking about turbo'ing my pinto, but i cant get hold of a efi manifold, so i was talking to a couple of ppl, and they said i can do a carby system with it, just get the floats and stuff done in my carby and run the turbo air intake to that. i was wondering if any1 has done this? or seen it done before, and if its worth that or gettin a manifold and putting a 40 something mm weber in and running the turbo into that? i looked at fuel injection but every1 does a sierra efi, but i cant find one or get hold of one. any1 that can help be happy 2 listen out 4 ya advice. James. |
06-06-2010, 04:47 PM | #2 | ||
do some searches for manifolds and bits in the UK...maybe the UK ebay...
Hate to say it, but I put heaps of these cars and motors through the crusher... Cheers Engine Guy |
06-06-2010, 08:10 PM | #3 | |||
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
06-06-2010, 09:23 PM | #4 | ||
Speak to a good carby shop and they'll be able to set it up. Maybe a small holley would be easier?
When the flag drops... The bullsh!t stops... |
06-06-2010, 09:42 PM | #5 | ||
are there many transit vans in australia?
cheers for the info guys. James. |
07-06-2010, 10:19 AM | #6 | ||
heaps of them...Aus Post used them... have a trawl around the van wreckers
07-06-2010, 01:38 PM | #7 | ||
Modify a weber manifold and run ITB's?
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
07-06-2010, 01:51 PM | #8 | |||
07-06-2010, 09:14 PM | #9 | ||
yea this guy in autobahn said about the xe carby. if i had the floats done would that be able 2 run a turbo flowing into it??
07-06-2010, 09:16 PM | #10 | |||
07-06-2010, 11:09 PM | #11 | |||
08-06-2010, 11:39 AM | #12 | ||
or you could just do it like they did 20 years ago or more, run a holley in front of the turbo so its set up like a suck through. A mate of mine set his up with a side draught webber in front of a TO4 with a cross over pipe to the standard intake manifold. Only thing though you will have to make sure is that you have a carbon seal installed in the back other wise when you back off the throttle after making boost it will force oil into the exhuast housing = heaps of smoke!!
Plus side with a blow through set up is you can run a intercooler. Ive seen it done on smaller engines, might be ok for the 2L but the centre point injection set up off an EA-EB Falcon. Will only need a computer to run the 2 huge injectors on it. Maybe a Jaycar computer could run it?
New engine on the way : Weisco Pistons, Total Seal rings, Crower rods, BIG lumpy stick, TO4E with back cut exhaust wheel 1.0 rear housing 30psi!!, major head modification! Bring on the 1/4 mile : |
08-06-2010, 10:48 PM | #13 | ||
cheers 4 that guys. u guys are legends. might hav a look 4 a xe carb, i kno where i can get the adaptor plate. and ill have a look out 4 a efi at the same time. cheers 4 all tha help.
James. |
