Old 12-06-2010, 08:43 AM   #1
kruptor
Custom Member
Default Question about intake manifold conversion on 2L pinto....
Hi,i have a mk2 1976 4dr escort sedan with a 2L pinto in it.I was just wanting to know if an intake manifold off a 1994 mazda 323 1.6L twin cam motor will bolt up to the pinto head????Maybe it can be another intake conversion???
I also have a twin cam head off the same motor i think the motor prefix is B6 or BP depends which one is 1.6 or 1.8 that model of mazda/laser cam out with those engine size options...
cheers Bryan
kruptor is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2010, 01:32 PM   #2
V8falcons
V8falcons's Avatar
No the bolt/intake pattern are different,but you could cut the flange of the stock 2ltr manifold and mate it up to the B6/BP manifold runners with abit of ingenuity and a welder.
Then you would have a cheap injection system.
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2010, 04:00 PM   #3
MR Turboesky
MR Turboesky's Avatar
have you considered a inlet manifold from a ford sierra? will bolt straight up.
Another manifold i have seen used is the magna manifold. have to move the throttle body to the end though.
May the boost be with you!
MR Turboesky is offline   Reply With Quote Multi-Quote with this Post
