01-07-2010, 12:35 PM | #1 | ||
ive just put a 302 cleveland into a te cortina and was wondering if standard clevo exhaust manifold will fit? are there different ones? i vave some out of a xd falcon but the outlet is facing into the firewall , can you get manifolds that face the outlet down?
01-07-2010, 10:22 PM | #2 | ||
Yes some of the early ZD ones and i think some F trucks use a Y type on the left with the outlet much lower. The right F truck ones curve over at the back but are quite long . The ZD ones are from memory face back but are shorter than the normal clevo ones .
01-07-2010, 10:41 PM | #3 | ||
This will show you . The right ZD is much shorter than these . Usually also these will take a 2-1/4" pipe
http://cgi.ebay.com.au/FORD-F100-EXH...item3a5c76662a http://cgi.ebay.com.au/ford-f100-150...item1c13afe2c8 |
