29-07-2010, 12:02 AM | #1 | ||
Custom Member
Hi,can any one verify if mk1 cortina has the same size/firewall dimensions as a mk2 escort???Also is the crossmember the same or similar?
Just asking because you can fit a 302 windsor into a mk1 cortina with very little mod to firewall and gearbox tunnel,so i was thinking is it possible to do the same engine converison to an escort and also doing the same mod??? I dont know so i am asking.cheers |
05-08-2010, 09:27 PM | #2 | ||
Mk2 Racer
I have a Mk1 corty and 6 Mk2 Escorts sitting in the yard but I don't think the firewall sizes are the same. I'll measure tomorrow. The Cortina will not fit on the Escort trailer, 2 1/2 inches (50mm) wider. We have fitted V8's in Escorts but mid mounted for racing not street. I doubt the suspension would cope with the weight unless you fit a Rover v8 much lighter and smaller. Plus I know where to get one fully rebuilt. Hm now you got me thinking.
Cheers, Les |
06-08-2010, 08:58 PM | #3 | ||
Mk2 Racer
Ok, dimensions are;
Cortina Firewall to radiator mount. 700mm Escort 600mm. Cortina between chassis 580mm Escort 600mm. Cortina Bonnet to Chassis 500 Escort 480mm. Cortina crossmember below chassis 100mm Escort 200mm. I was going to measure the Windsor 302 in my 70 Mustang but got too dark and damn cold. I reckon the firewall would need modifying. I had bought an Escort MK2 which had been modified for a V6 but can't measure that the chaps done a runner after being paid, can't find the car. any how I hope these measurements are some help Cheers, Les |
08-08-2010, 10:25 AM | #4 | ||
Custom Member
Thanks Les,will help a great deal.I've changed my option of engine choice im going with a windsor V8 for the conversion.
