Old 08-12-2010, 02:06 PM   #1
maca_404
Default Mk2 escort carby question
Hey
I have a 1980 MK2 Escort with the 1.6 kent motor, I would like to keep the original motor and do a few upgrades. I havent even look at which carbie is fitted stock mabye someone can tell me ?. But I do have a cortina gt manifold with the weber DFM carb and I wanted to confirm this would fit the esky as I believe they both had 1600 kent engines and also would it have a significant enough performance increase to warrant changing over from stock.
Thanks for any help
maca_404 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 06:27 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
your car will already have a dual throat weber carbie on it (complete with pollution gear)
the GT manifold & DFM carbie will fit, performance gain is very hard to judge as you will also be removing the polution gear which will change the performance but it is not a good thing if you get caught....
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2010, 11:29 AM   #3
peterw
peterw's Avatar
Changing a carbie just by itself shouldn't give you any increased performance unless there is a problem with the original carb. To get some gain you need to change the engine's ability to burn more air/fuel. Extractors, head mods or hotter cams are traditional ways to increase the flow in the combustion chamber and combined with a bigger carb should give performance gains.
Pete
70V6
peterw is offline   Reply With Quote Multi-Quote with this Post
