Old 09-12-2010, 12:05 PM   #1
jaydee
jaydee's Avatar
Default Definition of speed, some stats on a top fueller.
Very interesting read, apologies if a repost, I did check and found nothing.
DEFINITION OF ACCELERATION
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron, OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 12:10 PM   #2
MexicanBatman
MexicanBatman's Avatar
Seen it before and it's really impressive but I don't agree with point 3, a 747 can't be compared but they put out far more than 6000hp if you could compare thrust to hp
MexicanBatman is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 12:13 PM   #3
ratter
ratter's Avatar
I think the speed record is now around 324 mph in 1000 feet
Pit Lane Performance
Old 09-12-2010, 12:43 PM   #4
Boosh Brus
Not to mention a 747 can comfortably sit at 75% throttle for about 15 hours or so before running out of fuel or failing.
Boosh Brus is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 02:04 PM   #5
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
I find this amazing, but then 9,500 rpm for a second is 158 rev per second.
4.428 second pass is then 701 revs (not taking into account engine going from idle - full revs
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023, 2024
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 04:49 PM   #6
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Or clutch slip ..............
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 05:31 PM   #7
Windsor342ci
The Experience...
Windsor342ci's Avatar
Amazing...
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF
Their Pride: T3 TE50 Manual
Windsor342ci is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 08:08 PM   #8
TUF_302
The Vengeful One
TUF_302's Avatar
Wowee weewaa!
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2010, 09:41 PM   #9
yanknbank
Very regular
yanknbank's Avatar
Speaking to Phil Lamattina recently and he was saying his engine puts out around 8,500 HP. At full noise the sound travels right through you.
An amazing piece of machinery.
G6E Turbo Ego Cashmere .....The velvet sledgehammer
yanknbank is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2010, 08:05 AM   #10
DJM83
Barra Turbo > V8
DJM83's Avatar
Red it before, but i love this fact. These cars are a real feat of engineering
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2010, 07:49 PM   #11
GasoLane
Former BTIKD
GasoLane's Avatar
You've been watching this video/slide show, haven't you
http://www.break.com/usercontent/200...r-Facts-473754
Old 10-12-2010, 07:58 PM   #12
03 GHIA
Some amazing information in there that I never knew. Really shows the extent of engineering that goes into top fuellers.
Current
Viper 2010 50th Anniversary XR6T
Stock, but for how long...
Previous
White 2003 Fairmont Ghia
First- RIP.
White 1990 Ford Fairmont
Exhaust, intake, cam & lowered.
03 GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2010, 08:55 PM   #13
290GTP
290GTP's Avatar
As has been stated above, read it all before but top fueller stats never cease to amaze me.
Awesome pieces of machinery.
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534
Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw
RIP Fish 15/1/73 - 9/2/19
290GTP is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2010, 02:09 PM   #14
nb_351
building the xe...
nb_351's Avatar
cant wait til their aw wsid next, ill be taking the two boys theyll love it, i remember going as a youngen and i loved it with my earmuffs on lol
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
