Old 15-08-2007, 04:26 PM   #1
v8ghia1
v8ghia1
Default Help...my axles wont fit?
I recently purchased a chromed diff casing/housing for my 72 panelvan and have fitted the diff centre to it and had an attempt at fitting the axles....only to discover that the chrome diff has a narrower axle housing for the bearings?
My axle bearings are about 15-20mm
Chrome diff bearing housing is about 10mm.
Can anyone let me know what sort of diff casing I may have so I can purchase compatable axles.
v8ghia1 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 08:36 PM   #2
bad_mk1_escort
eskie freek
bad_mk1_escort's Avatar
post up a pix mate and does the centre of the diff drop out of do u have to take a plate of the back of the diff housing to get to the centre
black mk1 on goin project/ toy
94 ef xr8
toyota 60 series project with 6inch lift and 35z
Xd sedan project for sale
mk1 4 door project car for sale
Mk2 4door 1.6lt for sale
bad_mk1_escort is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 10:33 AM   #3
v8boss
There were two different size bearings, I assume you are talking escort? All you have to do is swap to the smaller size bearings. Press/cut the old ones off and install new narrower bearings and it should all go together. Check your axle lengths as well, as there were subtle differences between van, s/w and car diffs.
bigger Is better.
v8boss is offline   Reply With Quote Multi-Quote with this Post
