Old 21-03-2011, 05:15 PM   #1
barra265t
Default Wiring diagram FG and BA cluster
Hi, does anyone have or know where I can find the pinouts for the plugs on an FG cluster and also for a BA cluster. I've searched the technical documents section with no success
barra265t is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 11:43 AM   #2
barra265t
Default Re: Wiring diagram FG and BA cluster
Took the plunge and plugged the FG cluster into a BA. Turns out they are electrically compatible.
Was able to get an odometer and trip meter reading immediately when plugging in. With car off, the headlight symbol would work. When the car started, 'Ford' came up on the LCD screen, a red exclamation mark symbol flashed once and what appears to be an airbag warning light was on constant flicker, along with the cluster illumination. Temperature Gauge and Tacho worked with the car running. LCD turned blank, indicators didn't work, fuel gauge on empty, speedo stuck on zero. and my ICC color screen was switched off for some reason.
Old 22-03-2011, 12:14 PM   #3
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Its the wrong section of the forum, but I'm interested to see if you get this working properly and what it took to do this!
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 03:14 PM   #4
Paxton
Cobblers!
Paxton's Avatar
Your Cluster and ICC are hard wired into the computer system of he car, and need to be 'mated' (for want of a better term) at Ford. Whether or not this gets the FG cluster to work in a BA/BF is another matter altogether.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 03:48 PM   #5
barra265t
oh ok. Thanks for the info, do you work at Ford or something? Interestingly I think the plugs on an FG ICC look awfully similar to those on the BA/BF ICC, but I will need to view them side by side.
I was once told the BA/BF/FG BEM is identical.. is this true?
'Computer system of the car'.. isn't this basically the wiring of the car within the cabin with all its modules [RCM (airbag), BEM, HIM (heater box), ICC, Cluster) that run the cabin/electrics. I would have thought the engine bay wiring is sort of another circuit with basic info being sent to the cabin from the PCM. What makes me curious is that BF+ interior electrics are backward compatible with the original BA. BF underwent a major PCM/wiring change under the hood to Spanish Oak architecture from Black Oak architecture (BA), without needing major revision to the cabin electronics. And AFAIK, the FG runs the same Spanish Oak architecture (BF) or a revision of it.
Old 22-03-2011, 04:34 PM   #6
auMatt
ORSM Ford Cruisers
auMatt's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Matt's valued contributions in the technical area associated with AU/BA/BF & Terri instrument clusters & ICC's is considered the authoritative guide to work by members in this are of expertise. His contributions stand alone in the forum in this technical
The cluster won't work because it needs to be linked to the bem. The b series clusters didn't need this. The actual wiring is similar to a b series but with some variances. I also think the cluster uses a different style of can bus compared to a b series.
Matt
2004 Harvest Green XR6
Orsm Ford Cruisers
ORSM Ford Cruiser's Web Site
Contact me for all your Cluster Programming/Repairs & Window switch/ICC colour change for BA/BF/FG Falcons & Territory. Visit my SITE for info.
I Use and Recommend :
Ferntree Gully Auto Salvage
AutoWorks - Keilor
RIP Craig
RIP Samantha
auMatt is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2011, 04:57 PM   #7
barra265t
Matt
Cheers auMatt. Can you tell me if the FG BEM has the same plugs as a BA/BF BEM? Also, what is actually responsible for 'creating' the CAN bus in the BA/BF? Is it the combination of modules hooked up within the cabin, or does any of it originate within the engine bay (PCM)?
Old 22-03-2011, 05:05 PM   #8
auMatt
ORSM Ford Cruisers
auMatt's Avatar
No idea about the BEM but I would assume its different. All the modules talk across 2 different CAN Bus. There is a High and Medium speed bus if I remember correctly in the FG. There is no originating device for the CAN bus.
Matt
Orsm Ford Cruisers
AutoWorks - Keilor
RIP Craig
RIP Samantha
Old 22-03-2011, 05:06 PM   #9
barra265t
Matt
Thanks again Matt, much appreciated. The High and Medium speed bus run along the same 2 wires (CAN H and CAN L), or do they have seperate wiring?
Old 22-03-2011, 05:08 PM   #10
Paxton
Cobblers!
Paxton's Avatar
Nope. I just absorb information.
Ego BFII Ghia
Old 08-03-2015, 07:32 PM   #11
bigmat
Big Mat
I have gone a bit troppo I am fitting a complete fg g6e interior into my xf panelvan. I know that I will have problems with the fault codes for many non existent sensors and functions. I am running a old school big block v8 so it doesn't need any ecu.
I was hoping that the engine control was almost unnecessary for the bem icc cluster etc to operate.
Time will tell I guess.
My XR6 "Big Mat"
bigmat is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2015, 05:13 AM   #12
happy1
The speed signal would be a CANBUS message from the ABS-unit to the cluster, and the rev-counter would be a CANBUS message from the PCM to the cluster. An electronics guru could probably configure CANBUS emulators to send some of the packages to the cluster, but it will not be an easy DIY wiring job, and without it I believe the cluster will be 'dead' and with check engine light on, etc.
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2018, 12:18 PM   #13
chinamonty
The cluster reports its serial number during start up but I am not sure whether it requires an 'answer' before it works. Next time I catch up with people who used to work at Continental I will see if anyone knows. I have lost contact with the guy who did the circuit for the Ford clusters though.
chinamonty is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2018, 12:41 PM   #14
Tonz
This thread is 3 years old, well done ole china
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2018, 01:00 PM   #15
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2018, 04:49 PM   #16
Interceptor
HSV - I just ate one!
Interceptor's Avatar
thread might've been 3 years old, but its been a thought provoking thing for me....
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2019, 04:48 PM   #17
Bonn
Bonn's Avatar
If anyone's still subscribed to this thread, my problem is:
Have put a floor-shift cluster (XR50) into a column-shift ute and am getting the TRANSMISSION NOT IN PARK message, with Park well and truly selected.
Why wouldn't the pin-outs etc be the same??
Bonn is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2019, 11:41 AM   #18
Bonn
Bonn's Avatar
All fixed - 'column shift' needs to be selected, via scan tool
FG Falcon Ute
Daily: E-Gas 4.0 I6, 3 seat 1 tonner, 2300kg Tow Pack, Carryboy, XR6 rims.
6 Stacker, Sat Nav, Reversing Camera, Sunnie Holder, XR dash & St Wheel - thanks Mr FPV!
Jaguar XJ-S: Eaton S/C, I/Cooler, Haltech, DB7 rims, 1:15 Wakefield.
Jaguar XJ6 Wife's daily :2006 Quartz Metallic, FORD Duratec 3.0 V6, ZF 6sp
Previous relationships: FG GT, FG XR8 (+BA XT 5.4, BA AU, EF, EB, EA, EA & XF work cars)
Jags XJ12 & XJ6, BMW E39 Wagon, BMW F11 M-Sport wagon, 20 of GMH FC-HQ
