Old 20-05-2011, 09:21 AM   #1
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Default Digital Oil Tester
http://www.autoblog.com/2011/05/19/l...eking-backers/
Most of us maintain our vehicles either by the manufacturer's recommended service intervals or some arcane calendar handed down from generation to generation. Either way, changing a vehicle's oil is usually done on either a time or mileage basis, not the actual level of oil degradation inside the engine. A new startup project is looking to change that for the consumer with a device called the Lubricheck. Simply plop a few drops of oil onto the device's sensor, and it can automatically detect contaminates like metal and antifreeze as well as the acidity of the oil to determine the lubricant's serviceability.
The device even has settings for traditional and synthetic oils, so all of your bases are covered. Devices like these already exist in the market, but they cost a pretty penny and are typically relegated to the dark recesses of high-end mechanics' toolboxes. The individuals behind Lubricheck estimate that in some applications, oil could last as long as 10,000 miles before seeing significant breakdown.
http://www.kickstarter.com/projects/...r-for-your-car
Hell, I would definitely use this every weekend!
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 11:00 AM   #2
Gomez
Gomez's Avatar
Default Re: Digital Oil Tester
Originally Posted by Lubricheck Website
The combination of the two physics methods allows the accurately measurement of the quality of engine oil. The Lubricheck can determine acidity, metal particulate level, carbon level and any foreign liquids (except fuel).
Fuel dilution of oil is a major factor in the determination of an oils ability to perform.
The fact that this device can't measure fuel dilution, means that it's seriously compromised in my view.
Gomez is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 10:23 PM   #3
sudszy
Yep agree, not being able to check for fuel contamination is a concern, many cars do short trips on cold engines and knowing whether its really necessary to change the oil or not could extend the oil change for at least a year if the car doesnt get driven much.
Im sure there is probably a cheap paper test that could test for fuel, see what I can find out.
my recent territory comes with a 15000km service interval, obviously ford thinks the oils are good enough for that these days.
I also run a couple of vehicles on lpg, drop the oil out of these and it looks and feels brand new after 10000km, I reckon ive been throwing away perfectly good oil for years!
Yeh, they reckon the acidity builds up with lpg, well Ive measured that and found it a non issue, the cynic in me says its just a push from the oil companies to have us pay more for an lpg specific oil.
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 10:27 PM   #4
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
It loses its viscosity as it gets old though, right?
Old 20-05-2011, 10:45 PM   #5
sudszy
Not really, its not a time thing, more due to use(beaten up in the engine), but that is what you can feel when you rub it between your fingers. One reason ive discarded the oil that Im guessing is probably still quite good, the finger test is a guide, not a certainty. Be good to know if the oil is still within specs, though I dont know how this device does it, how does it know what grade of oil its meant to be testing? and then deciding it in the correct viscosity range, how can it actually test whether the viscosity modifiers are functioning at engine operating temp etc.
Old 20-05-2011, 11:39 PM   #6
Silver Ghia
Silver Ghia's Avatar
I have observed many times that during the 15000km service intervals with dealer oil, the oil level suddenly starts dropping, and when draining when warm, a portion of the oil is quite runny, almost like water. Found this also when I drained the oil from my FG for the first time at 7500km.
I suspect that this is caused by the oil breaking down, that the base oil separates from the viscosity additives that provides the multigrade viscosity properties of the oil.
This is my main concern with using older oil, that sludge can form from the additives that have separated, also the throttle body becomes grimey from the fumes of the degraded oil passing through the PCV valve.
The oil I have been using the last few years shows a consistent viscosity each time when draining after even 15000km, and also found that it maintains a perfectly clean throttle body, which supports my above theory regarding oil degradation.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
