Old 23-05-2011, 10:14 AM   #1
V8XTasy
Default what is actually done during a tune
hi,
I'm thinking of taking my BA 5.4 V8 3v Falcon for a tune as I've put an aftermarket exhaust on it, but I'm confused as to what get tuned (I haven't had an engine tune on a modern engine with a PCM before). If they increase the fueling, doesn't the closed loop system detect a rich mixture and lean it out anyway? And if it's already too lean, wouldn't the system enrichen it? What other things do they do to increase performance?
Thanks
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 10:35 AM   #2
Grippy
Racing improves the breed
Grippy's Avatar
Default Re: what is actually done during a tune
Air Fuel ratios are tweaked, if auto shift points and harshness can be changed. Rev limits and points can be changed and different tunes for different fuels can also be modified and stored.
1970 Mini Cooper S Historic Group Nc Touring car
1964 Mini Cooper S Historic Group Nb Touring car
2024 Subaru Outback Touring XT
Victorian Hill Climb Championship
Grippy is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 11:20 AM   #3
Tobey
BF Ute...
Tobey's Avatar
They will also add more spark, change temperature settings (fans), idle control, the list goes on...
Best to pick a tuner then ask them all of the questions.
Tobey is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 01:03 PM   #4
madmelon
Closed loop mode only occurs at low throttle positions. At high(er) TP, the system runs in open loop and this is where the performance tuning is done. Fuel can be changed to do whatever is requried here, along with other things.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 01:26 PM   #5
V8XTasy
Thanks, I just tried it with my OBD scanner and found that it does exactly that, I never realised that before. Time for a tune.
Old 23-05-2011, 04:02 PM   #6
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by V8XTasy
hi,
Thanks
A tune is more likely to lean the mixture a bit than richen it, as the factory tune is nearly always on the rich side to cool the cats and to allow for a bit of fuel pump degredation over time, among other things.
A tune changes the parameters the ECU uses to detect a rich or lean mixture, so if it went richer it would not lean it out because as the base parameters have been changed it will not adjust it as its already where the ECU tells it it has to be. Thats what a tune entails, changing the base parameters the ECU uses to adjust fuel and spark etc.
Old 23-05-2011, 05:45 PM   #7
xtremerus
FG XR6T trayback
xtremerus's Avatar
Does it need a tune for just an after-market exhaust??
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 06:40 PM   #8
xls3v
xls3v's Avatar
mine made 224rwkw after a tune, exhaust and airbox mods.. great mod picked up around 25kws from the tune
xls3v is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 07:19 PM   #9
SteveJH
No longer a Uni student..
Would depend on model I6, I6T or V8. In addition it depends on whether its a full exhaust or just catback.
SteveJH is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2011, 06:52 PM   #10
Bossxr8
Peter Car
Bossxr8's Avatar
Not for a catback, maybe for a full system if its Euro 3 and it has post and pre cat oxygen sensors as changing the exhaust can bring on the engine check light.
Old 25-05-2011, 05:38 PM   #11
lamborghinifan
lamborghinifan's Avatar
i'm actually in the same boat here with a 3v and soon to be sports exhaust on it. also on injected gas. does it need a capa box or flash tune? don't really know what these things are exactly or how much is within the limits of the onboard control modules?
lamborghinifan is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 05:48 PM   #12
kinksta
Luxojet
kinksta's Avatar
If I can ask, how much in total for 25kws?
Rides:
-Toyota Blade Master G.
-Ford G6ET (that will be for sale)
kinksta is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 09:31 PM   #13
V8XTasy
I had a quote from 1 place for $1500 for a dyno tune, seems a bit steep. What do you think?
Any suggestions for a good place to take it around West or North Melbourne? I know there was a thread on this previously, but it was a bit old and some places have closed down.
As well as the catback exhaust, I'm doing the intake mods; replacing the intake tube, F6 additional intake and K&N filter.
Old 25-05-2011, 09:44 PM   #14
Phyber
BF= Backend's Farked
Phyber's Avatar
Did that include an XCAL tune box as well?
Generally tunes seem to be $600-$1000 from most sponsors (my tuner XFT is $1000). If it's a B series or FG the XCAL3 box they use now is like $800RRP or something.
BFII XR6T - ZF box
Racewars 2017 result - 800m @ 229km/h - 1000m @ 241km/h
PB: 317rwkw - 11.94 @ 120mph - 2.093 60'
PB: Stock/208rwkw - 13.594 @ 105mph - 2.297 60'
Phyber is offline   Reply With Quote Multi-Quote with this Post
