Old 25-05-2011, 10:16 PM   #1
pewie72
Default New exhaust - resetting the ECU
Advice please...
Do I need to reset my ECU for a newly installed exhaust system from the Y pipe back? It is for a BF XR8.
If yes what is the best way?
Appreciate some advice
pewie72 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 11:04 PM   #2
excessfg
Default Re: New exhaust - resetting the ECU
mate you should reset your ecu, as the ford ecu's are self learning and resetting them would go back to basics. simply disconnect the battery for approx 30-45 minutes, re-connect the battery and then let it idle for 15 minutes, then take it for a good drive. i re-set the ecu in my xr6t yesterday.
excessfg is offline   Reply With Quote Multi-Quote with this Post
