24-07-2011, 12:04 AM | #1 | ||
rexnet
will FG seats fit into an AU.
been trolling FTG's section and some FPV seats would be pretty hectik for front seats. |
24-07-2011, 12:13 AM | #2 | ||
ROCKING THE EL FUTURA
mabe, you'll have to mod the rails i reckon....
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
24-07-2011, 12:15 AM | #3 | ||
rexnet
lame. i guess this will never happen anyway. but its a nice pipeline dream
24-07-2011, 01:41 AM | #4 | ||
they are not even close it is a major job requiring and engineers certificate to prevent voiding all your insurance including CTP.
[SIGPIC][/SIGPIC]
24-07-2011, 02:37 AM | #5 | ||
Yeh, the rails on the AU will need to be modified to fit those seats. Maybe just get a set of custom leather if your looking for something different?
24-07-2011, 07:33 AM | #6 | ||
rexnet
Ehh. I'll just wait till I get another wrx. The feeling of being hugged all the time is great for the hills
24-07-2011, 09:51 AM | #7 | ||
Pro Street Au Ute
the au seat design is crap imo. The seat base sits between the rails not on top like all other falcons. I bought ba gt seats to put in my au ute but now am putting them in my eb as they bolt straight in with a spacer, back seat is different but atleast it will get used.
I ended up putting sports racing seats in the au and its not worth it i reckon. I had to cut everything away til i was left with just the rails then welded two 50mm wide by 4mm thick strips of steel across the seat rails while bolted in with an inch over hang for strength. Which sat flat on the rails and slid perfectly and everything, BUT when i mounted the seats my head rubs the roof and its hard to get in and out as the seat sits much higher. No other seats will sit lower, ba seats would sit the same height. There's only two ways to go lower. 1 bolt them straight to the floor ie fixed or 2 cut the floor pan and lower it. Imo getting standard seats rebolstered is the only way to go. Good luck to anyone trying though. |
24-07-2011, 10:14 AM | #8 | |||
I cringe when ever I read "I just cet and welded the rails. seats and their rails are tested to a high standard because of the hard work they endure . wher people just weld them up give them a quick shake and say she'll be right. modifying seats is illegal and dangerous. you need them certifyed by an engineer for a good reason. Imagine you're going through a twisty road quickly, the sidewards force causes the seat to break loose and suddenly you're floating all over the place trying to get through a hairpin with a 200M drop on one side not a good or safe thing
[SIGPIC][/SIGPIC]
Everyone starts off with a bag full of luck and an empty bag of experience. The trick is to fill the experience bag before the luck bag is empty. "It is better to remain silent and be thought a fool than to speak out and remove all doubt." Start a new career as a bus driver Rides: FG2 XR6 stock at this stage but a very nice ride xc 4 DOOR X CHASER 5.8 UNDER RESTO Last edited by FGII-XR6; 24-07-2011 at 10:20 AM. |
24-07-2011, 01:02 PM | #9 | |||
rexnet
As far as I've heard in the way of putting a more sports supportive seat AU's are lame. Wrx FTW |
24-07-2011, 02:15 PM | #10 | |||
Pro Street Au Ute
24-07-2011, 06:17 PM | #11 | |||
True you are entitled to your opinion no matter how poorly it is thought out.
The AU seat design has been proven to be reliable compared to later models which break when made to do any serious work, having seen the serious seat breakages in B series taxis I would never put one of these poorly designed ( some might even say dangerous) seats in my car even if they bolted straight in. As far as interchanging is concerned no seats are designed with this specifically in mind, you can't put B series seats in an XY either are they poorly designed too? Designs change and evolve sometimes better sometimes worse, saying the AU seat design is poor because you can't bolt B series seats in is like saying an E series is badly designed because an AU or B series motor won't bolt straight in without modification Quote:
[SIGPIC][/SIGPIC]
24-07-2011, 06:26 PM | #12 | ||
Next upgraded Mk1 Leopard
Has anyone found a standard car seat (from any make, even..Holden..) that fits straight into an AU? Just wondering.
UK
24-07-2011, 06:48 PM | #13 | |||
FG POWER
hey buddy
my mate used to have an au ute and he put xr b series seats on im pretty sure they went straight on :P
2009 FG XR6 EGO
24-07-2011, 10:11 PM | #14 | |||
rexnet
24-07-2011, 10:13 PM | #15 | |||
rexnet
If it's the one I'm thinking about |
25-07-2011, 10:04 AM | #16 | |||
[SIGPIC][/SIGPIC]
25-07-2011, 10:37 AM | #17 | |||
rexnet
Or buy a wrx |
