Old 27-07-2011, 05:29 PM   #1
danscort
danscort's Avatar
Default Steering Rack Issue?
Hi, My mk1 Escort is having problems with the front end, I got told about a year ago by Bridgestone that I needed to replace the steering rack when I got a wheel alignment. Now the car shudders when I brake. It got worse over time. Question is - Is the steering rack the reason? I would like to know before I replace it.
danscort is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 06:12 PM   #2
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Default Re: Steering Rack Issue?
Nope. It'll be warped rotors. Get them machined or repalce them. That'll fix it
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 27-07-2011, 06:59 PM   #3
danscort
danscort's Avatar
So the steering rack can't be the problem? The reason I ask is I don't do hard braking with the little 1600 so I thought the rotors wouldn't have a problem with getting too hot and warp.
Old 27-07-2011, 08:59 PM   #4
caprispecial
Any looseness anywhere in the front end will cause problems with wheel movement. SMCKA parts has a rack repair kit, if it hasnt been done for some time its probably needed.
caprispecial is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 09:16 PM   #5
svo supporter
Time also warps rotors, not just hard braking etc etc.
I surpose there's a few questions I forgot to ask, which would eliminate the rack being a problem.
Does it wobble when you don't brake at speeds round 70 KPH +?
Is the car a "pig" to drive above 40 KPH? ie, the steering wheel wobbles and you're constantly correcting the steering whilst driving in a straight line and the wobble gets worst as you increase speed?
Do you have a saw tooth effect on the tyre edges?
Old 27-07-2011, 09:24 PM   #6
danscort
danscort's Avatar
So it could be either disc rotors need machining or steering rack needing a rack rebuild kit. How do I check which it is?
Old 27-07-2011, 09:30 PM   #7
danscort
danscort's Avatar
Tyres are fine, It only shudders when I brake at any speed and the steering wheel goes left to right (should have said).
Old 27-07-2011, 09:32 PM   #8
danscort
danscort's Avatar
Shuddering threw the steering wheel*
Old 27-07-2011, 11:39 PM   #9
svo supporter
Stuffed front end parts including rack = tyre wear problems.
Brake pads need an even surface to press against to prevent wobbles once pressure is applied.
Now I'll leave you guess what the problem would be from that.
Old 27-07-2011, 11:58 PM   #10
danscort
danscort's Avatar
Smile Re: Steering Rack Issue?
Thanks for the help svo supporter
Old 28-07-2011, 12:00 AM   #11
danscort
danscort's Avatar
Got a mobile guy that does my workmates cars, Ill ring him tomorrow.
Old 11-08-2011, 01:22 PM   #12
danscort
danscort's Avatar
Discs machined, problem solved.
Old 11-08-2011, 01:47 PM   #13
obsesscort
obsesscort's Avatar
Do you mind me asking how much machining the disks cost?
Regards,
Tim
1978 Ford Escort Panelvan
obsesscort is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2011, 07:25 PM   #14
danscort
danscort's Avatar
My mechanic near work (RAA approved) did it for $99.50. I work at Royal Park, SA. The mechanic my wife takes her car to said he would do it for $77 Salisbury South.
Old 12-08-2011, 12:56 AM   #15
svo supporter
****......Oops sory about the language. You got ripped severely. There's 2 places at Salsibury North, I am aware of, that do them for $35 ea.
Old 12-08-2011, 12:14 PM   #16
danscort
danscort's Avatar
I took it to the place near work as it was easier (walking distance). What are the places in Salisbury North called?
Old 12-08-2011, 04:50 PM   #17
allanv6gt
Tippy-tronic Free Zone
Sometimes it is worth paying a little bit more it it is walking distance, rather than have lost hours driving around town (for 99-(2*35) = $29)
Old 12-08-2011, 04:56 PM   #18
atec77
It might be disks but usually it's the cup and post on the end points on the rack , there used to be a kit which replaced the swivel points and collars but now you might have to replace the rack
Old 12-08-2011, 09:20 PM   #19
svo supporter
ABS and Torque Tyres. Both on Commercial Rd.
Old 13-08-2011, 12:19 PM   #20
danscort
danscort's Avatar
The mechanic said the steering rack needed replacing - next on list.
Old 15-08-2011, 06:51 AM   #21
Puzzlescort
Rally Nut
Puzzlescort's Avatar
The caps on the end of the tie rod arms are the main points of wear, the steering rack kit replaced the plastic bush with a metal bush. I did this in my quick rack some years ago and havent had a problem since (plenty of events on dirt)
I would suggest that if you intend to keep the car for a while I would just look for a quick rack & replace it (approx $210). dont forget to replace the bushes that hold the rack to the cross member, then have a look at the flexible steering joint
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 06:24 PM   #22
danscort
danscort's Avatar
Can I buy a quick rack here or do I have to get it from the UK?
Old 01-09-2011, 02:43 AM   #23
Grandmaspec
Old Mate
Grandmaspec's Avatar
I was hoping it would be the rack, quick racks are fun. I got a 1.2 (maybe1.4) from racetune in Perth. Can't remember how much it was but it's a bit cheaper if you trade in your old one, no matter the condition. Interesting at high speeds in the wet...
Grandmaspec is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2011, 08:08 AM   #24
Jimmyd
Try Smcka - top quality product and reasonable pricing - all my dealings with him to date have gone flawlessly.
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 07:14 PM   #25
smh00n
State of Confusion
I've got rack rebuild kits and brand new 2.9 and 2.4 racks in stock now. New shipment just arrived so may not be on the site until Monday/Tuesday after I sort it all out.
2016 FGX XR6 cab chassis
1970 Mustang base Sportsroof
smh00n is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2011, 05:35 PM   #26
JG65TE
JG65TE's Avatar
I see machining discs as a useless exercise these days as its not too often they come up within spec, next roady dont be surprised if you are done for undersize discs. They are cheap as anythin brand new now
example : http://www.ebay.com.au/itm/FORD-ESCO...item415cb5846b
JG65TE is offline   Reply With Quote Multi-Quote with this Post
