Old 04-08-2011, 01:42 PM   #1
reddevil6
Default what size exhaust for 2L rs2000
Hey im getting a RS2000 mk2 and i want to get a new exhaust for it because atm it had a 3 inch that comes out the side of the car behind passenger door, and not muffled i dont think. now the side exhaust is defectabale right? i was thinking a 2 and a 1/4 inch would be nice, im not sure whats been done to the motor but i know its had head work a new cam and maybe more. and where would a good place to buy from?
reddevil6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2011, 06:48 PM   #2
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Re: what size exhaust for 2L rs2000
HI MATE
well 3 inch way to big for the car anyway..even 2.5 is to big i think. but 2 and a 1/4 sounds the goods even 2 inch is great..in brissy i would say fat pipes in lawtton , great price and great workmanship..by far
cheers
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2011, 07:03 PM   #3
Russ
Russ's Avatar
I wouldn't go any bigger than 2 1/4 inch, a set of headers added (if it doesn't already have them) would give it a bit more power as well, just my opinion but anything over 2 1/4 inch on that sized engine is a waste unless it's turbo charged or has had a lot of work done internally in which case 2 1/2 inch should do the trick nicely
Old 04-08-2011, 08:40 PM   #4
shepv8
V8's for ever
The RS motorsport forums have some threads on this issue as well as some really cluey blokes who can sort you out. There is a formula that exists for figuring it out, much like for carburetion - taking into account capacity, revs etc. My RS 10 years ago had extractors and a 2 inch exhaust on a modified engine and it ran well. I think this time I may look at 2.25' . I think any bigger on a street motor is just noise for a pinto
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2011, 01:46 PM   #5
SBRacing80
2 litre motors like back pressure, 2 1/4 inch exhaust is more then enough for the street. i have a mk1 2 door circuit car with the 2 litre pinto, big cam, twin 45 dcoes with extractors and a 2 1/4 exhaust plus a hotdog and rear muffler and she screams. (shes also for sale...) if you run too big of an exhaust you can damage your valves and or overheat your motor.
cheers
SBRacing80 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2011, 02:01 PM   #6
jjw
powered by Ford
jjw's Avatar
I got a stainless mandrel 2.25 built by CES at Logan (are you in Brissy?) not cheap but good and will likely outlast the car!
jjw is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 08:46 AM   #7
davus
just on this, can anyone verify what the standard size of the exhaust would have been on a mk2 rs2000?
I have measured mine at 2 inches, and just wanting to figure out what standard is.
Dave
davus is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2012, 03:12 PM   #8
Pazuzu
Got a 2 inch setup from Rob Bliss in Geebung, Brisbane. Did some good work, he used to do Escort exhausts from sunrise to sunset back in the day, & I'm rapt with what I got for my $$$.
2 inch exhaust is the ticket, 2 & 1/4 is also good. Any bigger, & you won't be getting any kick unless you're already flying.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2012, 03:39 PM   #9
johno9184
74 mk1 2 door escort:
ive got worked 2ltr Pinto with twin 45 webers. its got a muffler and a hotdog and 2" seems more than enough
johno9184 is offline   Reply With Quote Multi-Quote with this Post
