Old 21-08-2011, 02:52 PM   #1
Tokyo Geoff
Tokyo Geoff's Avatar
Default GPS with front on/off switch?
Hi All
I want to get a GPS to mount in the tissue box cavity on my FG but I need one with a front facing on/off button. I like the Tomtoms but the switch is on the rear. Can they be hard wired to auto start?
Has anyone seen one preferably with multi media capabilities too?
cheers and thanks
Geoff
Tokyo Geoff is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 03:24 PM   #2
scottyg938
Stock Boss
scottyg938's Avatar
Default Re: GPS with front on/off switch?
I think most auto start when they are plugged into a power supply
03 BA XR8
Blueprint | Manual | Leather | Premium sound | Sunroof | Shockworks coilovers | TrueTrac + 3.73 Diff Gears
scottyg938 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 03:34 PM   #3
Tokyo Geoff
Oops did not know that, thanks
Old 21-08-2011, 04:09 PM   #4
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
That is correct - I wired mine to a permanent supply (they are 5V so you have to retain the little power pack) by putting an accessory power socket under the dash and taking the power feed from an ignition on fed circuit.
Works fine - the only downside is that the thing will be useless when not powered after it's been used like that for awhile.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 05:06 PM   #5
nstg8a
3..2..1..
nstg8a's Avatar
wont be the bigger issue be mounting it so the sensor is still able to see the sky?
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 05:10 PM   #6
flappist
Garmin work well with the auto power on from acc power. Tomtom do not.
I have no idea about any of the others.
Old 21-08-2011, 05:45 PM   #7
Tuddy200
Reaching for 200...
Tuddy200's Avatar
Most GPS can be connected to an "external" ariel which is what the OP will probably do.
Tuddy's XR6
04' BA XR6 - Blueprint - 6 Speed with Rip Shift - HD Clutch
2.5"/BFGT Exhaust System with Quad Tips - 4490's Extractors
19" ROH Flares - 20% Underdrives - Interior Colour Coded - Sunroof - BOSS Bonnet
Stage 2 Crow Cam's - Crow Cam's Valve Springs - BPR Airbox
M86 LSD Diff with 4.1s - Upgraded Brakes with Slotted DBA 4000's
Leather Interior - Rear Power Windows
Projects Underway: Sound System
Tuddy200 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 06:19 PM   #8
flappist
No most satnavs will work anywhere in the car. Mine is in the datto cuby hole an my wife's is on the centre console of her BA
Old 21-08-2011, 06:20 PM   #9
nstg8a
3..2..1..
nstg8a's Avatar
interesting, makes finding one for my bike a bit easier.
Old 21-08-2011, 06:24 PM   #10
flappist
I have a garmin zumo 550 for my KTM. It comes with a second car mount that I use in the xy bash car
Old 21-08-2011, 06:28 PM   #11
kenz
BOSS Pilot
kenz's Avatar
mine sits nicely behind the gear stick in the opening under the tissue box slot in the BA and it still seems to work fine
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 11:28 PM   #12
JamesR
one thing you'll want to keep in mind is making it so its not too difficult to remove. need to update those things every so often
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
