Old 29-08-2011, 08:48 PM   #1
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Default Electron Microscope technology to check for surface defects
http://www.caradvice.com.au/135205/f...rface-defects/
Ford engineers use Scanning Electron Microscope technology to check for surface defects
By Brett Davis | August 29th, 2011
Ford engineers are using Scanning Electron Microscope (SEM) technology to observe their vehicle’s panel surfaces under fine detail to make sure there are no defects. The intricate investigation methods are usually used by forensic scientists and can detect surface defects well beyond what the naked eye can pick up.
The SEM technology allows Ford engineers to ensure critical materials are defect-free by giving them extra-close detailed imagery of any surface. To give you an idea of its power, the average human hair is around 0.07mm thick. The SEM scanner is able to provide details of objects under 0.000001mm in size.
The SEM scanner does this by using electron beams which are bounced off the material’s surface, rather than light waves like a more conventional microscope. Roger Davis from Ford of Europe’s materials engineering and testing department recently said,
“We need to investigate possible reasons why a development part may not meet our stringent requirements. In some cases that reason can be the smallest anomalies, something that can be found by using the Scanning Electron Microscope.
“The machine can magnify a part by up to 200,000 times and make it look quite surreal, but to the trained eye any defects become quickly apparent at these levels of magnification.”
Ford has begun using the scanners for development and testing of its materials that are used on new Ford vehicles.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:47 AM   #2
Bad Bird
Watts a panhard.
Bad Bird's Avatar
Default Re: Electron Microscope technology to check for surface defects
I've done some playing with SEM, it's a very cool technology. You should see the turbos they use to evacuate those chambers to 'hard' vacuum.
I don't have low self-esteem. I have low esteem for everyone else.
Bad Bird is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 02:19 PM   #3
2011G6E
2011G6E's Avatar
Really?
Come on...even the edge of a surgeons scalpel looks like a rusty lump of dinged up pig iron under an SEM. Why would you need to look at a surface that finely, especially if it's for car panels...?
Seems like a gimmick to me.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 02:33 PM   #4
Gobes32
Gobes32's Avatar
It's hard enough making good panels under a human eye, I call this a publicity hack.
Originally Posted by jpd80
A G8E would be good if Ford marketed squarely at Calais V8 owners. They need to bring back the walking fingers like in the initial FG ads, but this time have the fingers crushing Calais' as they walk along, with some relaxing background Led Zeppelin music and Marcos Ambrose in stubbies and singlet driving it.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 04:56 PM   #5
2011G6E
2011G6E's Avatar
Yes, even for engine components in production cars for the public, there's no need to go to that level of fineness of surface. There's some other motive behind it...crowing to the public about "look how much care we take with your cars surfaces...we look at them on a level below the microscopic to ensure they are as perfect as possible for you...something that even those hacks at Rolls Royce don't do!!"
