Old 19-09-2011, 07:33 PM   #1
shepv8
V8's for ever
Default Brake cylinder replacement
http://www.ebay.com.au/itm/FORD-ESCO...item20bcd29767
Hi all,
can anyone tell me the effect of fitting this master cylinder 20.6mm bore to a Mk2 Rs2000 with a 19.05mm bore ( I think its that size)
Will this work or create problems with the braking system. I am trying to track down a new master cylinder ans also rear drum wheel cylinders but they are a bit scarce.
Shep
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 10:55 AM   #2
feral
Default Re: Brake cylinder replacement
Do you have a master cylinder at the moment? If so, they can be rebuilt. I had mine done last year at Power Brakes in Adelaide. They require an exchange or for a premium they may sell you one outright.
ZJ Fairlane 351C
SY Territory
Skicraft Excel 350 Mercruiser
feral is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 11:37 AM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
i have done a few brake conversions to Triumph TR7s
i modified a VS commodore booster and used the matching master with it.
being bigger bore it does make your pedal a bit harder
eg the pedal pressure required to apply the brakes is more
also look at rear wheel cylinders from a 69-72 Capri, pretty sure they'd fit or be easily adaptable
i bought a set a few years ago, they were PBR gold's and were $20 ea brand new
cheers, craig
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 11:59 AM   #4
Jimmyd
Rear wheel cylenders - forget the horribly expensive Escort 2 litre spec'ed 64677551, you can use P10035 - same exterior dimensions/mounts, same 3/4 bore size.....
Alternatively if you want to play with braking bias, smaller (11/16 bore) P10033 for less rear bias, larger (13/16 bore) P10036 for more rear bias.
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
