Old 21-09-2011, 12:15 AM   #1
james05111
james05111's Avatar
Default Gaskets??
Hey I just bought a 2L mk2 escort planning on taking out the engine and gearbox to put into my 1.6L mk2 escort that is in better condition. I was just wondering if anyone knew what gaskets/seals/parts I should replace whilst the new engine is out of the car?
Thanks
james05111 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2011, 09:20 AM   #2
Jimmyd
Default Re: Gaskets??
Manifold gaskets, three front oil seals, rear main seal, tappet cover gasket, Sump gasket.
Obvious things like oil, oil filter, plugs, points, etc
Check condition of cam - largest journal is at rear of head, if cam is worn best to replace now rather than having to remove the head down the track to do the job.
Always a good idea to replace the cam belt while you have easy access.
Check, and I mean really check your welch plugs, particulalrly the in the back of the engine.
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2011, 10:42 AM   #3
james05111
james05111's Avatar
Thanks.
what do i check the welsh plugs for is it leaks?
Old 26-09-2011, 10:50 PM   #4
Jimmyd
Yep - any sign of corrosion replace them; MUCH easier to do it out of the car...
Old 02-10-2011, 09:43 PM   #5
allanv6gt
Tippy-tronic Free Zone
Welsh plugs are dirt cheap, and total failure is ultra-catatrophic ($$$$$)
