Old 04-10-2011, 08:11 AM   #1
blackxt
blackxt's Avatar
Default help. 14 inch stockies for escort
im wanting to no what 14inch stock steel rims will fit a mark2 escort i was told cortina fitted untill i got them and there wrong offset , ive read that mabey saab might fit , eny help would be great
thanks nathan
blackxt is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2011, 10:38 AM   #2
FOMOCO 1
Munch Munch GM's 4 Lunch
FOMOCO 1's Avatar
Default Re: help. 14 inch stockies for escort
saab interceptors do fit
FOMOCO 1 is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2011, 10:55 AM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
4cyl Chrysler Centura 14" rims are a direct fit too
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2011, 01:45 PM   #4
jjw
powered by Ford
jjw's Avatar
? are you sure cortina don't fit?
The pcd is 4 x 108mm and is common to 105 series alfa, some SAAB and some peugeot (but all have a much bigger offset than ford use). However, I have found that ford rims to be the easiest and cheapest options when looking at wheels for my alfa (but again, the offsets are wrong).
jjw is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2011, 02:33 PM   #5
my67xr
my67xr's Avatar
the late model TE and TF used a very shallow dished rim, their suspension is a wishbone setup.
if you fit them to an escort they foul on the struts
the Centura 4cyl 4 stud rims definately fit and work well on the Escorts
late model mazda 121s 96 etc, used the same pcd and 63.4 bore
and came with skinnys, 145x 60x 14s if you ever want 14" front runners.
although i have never tried them out
alfa's with the 108 pcd use a 35-42mm offset and a 57.1mm bore
there are a few other cars that use the same pcd
4x stud 850 volvo
some audi
a few citroens too
but like posted above the offsets are too wrong to fit them
67 XR Fairmont
Old 04-10-2011, 07:33 PM   #6
blackxt
blackxt's Avatar
yeah its hard to get the right offset and i dont want to run spacers , centura wheels would be rarer than rocking horse **** aswell wouldnt thay
Old 04-10-2011, 08:08 PM   #7
Neale
Neale's Avatar
If your after some saab ones I know a guy selling a heap of them for $25 a pop
Neale is offline   Reply With Quote Multi-Quote with this Post
