Old 05-10-2011, 10:03 PM   #1
xg-ute
Default Mk 2 escort
Hey guys,
Been a memeber on the forum for a while as a falcon owner.
But recently purchased a Mk2 escort GL, its an auto 1600,
It resonable condition but has had an accident with a smashed up drivers door and guard. but apart from that pretty good.
always loved the escorts and looking forward to getting stuck into this one.
Anyway Ive started doing some research into freshening up the motor and get a bit more power happening.Also lookign at doing a manual conversion.
Ive found a 4spd from a mk1, I belive this will bolt straight up, can anyone confirm for me?
Also anyone got any advice on engine upgrades,
Im thinkin carby?
and manifold to suit.
then extractors/exhaust,
and a upgraded cam of some sort?
Anyone got any thoughts or advice, not looking for anything amazing but just get her running nicely.
cheers Henry
xg-ute is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2011, 11:15 PM   #2
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
Default Re: Mk 2 escort
Hi Henry
The best performance upgrade for an Escort is to go for a 2 litre. However, if you are goin g to stick with the 1600, a couple of easy and cheap mods aer an air filter and extractors. not sure what cams are about for the 1600, but a Kent fast road cam would work nicely. However, if you are going to the expense of cams and carbies, you are better spending the cash on a 2 litre.
Have fun...they are an awesome car.
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:42 PM   #3
xg-ute
yeh mate id definately be keen on putting a 2ltr in,
its just trying to find one, but yeh if itll be worth my while waiting until i can source one i might aswell.
Ill keep my eyes open and see what i can do, im in no real hurry so may as well do it properly
cheers mate
Old 06-10-2011, 11:19 PM   #4
shepv8
V8's for ever
Originally Posted by RSgerry
Hi Henry
agreed. Best start is definately with a 2 litre, especially if you're going to the efoort of changing the auto for a manual. Theres a few 2 litre pinto motors on ebay at the moment and they always seem to come up
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 11:19 PM   #5
wombat2509
wombat2509's Avatar
I agree with RSgerry I just pulled the 1600 out of my Capri and put in a 2 litre with a 5 speed behind it unbelievable difference, the 1600 was sick but it now flies worth the change.
wombat2509 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2011, 09:48 PM   #6
xg-ute
ok youve convinced me haha, the hunt is on for a 2litre
if anyone knows of someone with one let me know ;) im In WA
Old 07-10-2011, 10:22 PM   #7
Les
Mk2 Racer
Les's Avatar
Henry,
I'm in SA, Whyalla but I do have 8 x 2L motors and 4 speed gearboxes, if you have no luck over your way we could always work something out. a 2 L cortina engine and gearbox will go in minus exhaust manifold (gets in the way of the steering column) just put extractors on.
Cheers,
Les
Les is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2011, 11:01 PM   #8
xg-ute
ok cheers Les,
Ill have a think about it, the freight cost may be the killer I reckon.
but we'll see how desperate I get.
appreciate the offer
Henry
Old 10-10-2011, 12:31 PM   #9
feral
If I recall correct with a cortina engine you have to switch the sump as well???
ZJ Fairlane 351C
SY Territory
Skicraft Excel 350 Mercruiser
feral is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2011, 10:46 PM   #10
xg-ute
yeh right, has anyone else heard of or done this?
so with an escort sump, im guessing the 1600 sump wont fit?
Old 13-10-2011, 07:43 AM   #11
Puzzlescort
Rally Nut
Puzzlescort's Avatar
if its a cortina motor YOU WILL need an escort sump & oil pickup -cortina pick up is at the front, escort is at the back
the front radiator support will need to be modified as well (real easy), then wiring loom modified to suit as well
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 12:50 AM   #12
xg-ute
ok cheers mate, will see what i can find will try get an escort motor is i can.
Old 14-10-2011, 01:23 AM   #13
atec77
If you do fit the old ford 2 litre and not a nissan as so many do then replace the valve gear oil feed tube , they crack often
Old 15-10-2011, 10:19 PM   #14
xg-ute
ok thanks mate will do
Old 19-10-2011, 12:57 AM   #15
james05111
james05111's Avatar
I had a 1600 auto and bough a wrecked 2L manual for $500 if you have the room this makes it a really easy swap as you can see how everything fits together as you take it out and there is no need to buy all the little bits such as the clutch cable and pedal box that you don't really think about when looking for the engine and gearbox. on mine i had some problems with the gearbox cross memeber but this can be easily fixed with some blocks between the crossmember and the floor. or a homemade crossmember if you are know someone good with metal. also keep the old tailshaft off the 1600 as it is way better.
james05111 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2011, 05:07 PM   #16
xg-ute
yeh cheers james, thats definately the way to go i agree.
Im in no real hurry with it so ill just keep an eye out and hoepfully something comes up.
Yeh right ok, i know a few people who are good with metal so shouldnt be a problem.
Old 26-10-2011, 03:20 PM   #17
ESS KEE
ESS KEE's Avatar
in WA go see
Rolly at Racetune
7/6 Chalkley Place
Bayswater WA 6053
(08) 9371 3333
or Tony at Escort Road and Race
3/51 Gillam Dr
Kelmscott WA 6111
(08) 9390 2213
either of them should have everything you need.
also, if ya keen, come along to one of our meetings, http://www.fordrallyesportclub.com.au/
guys in our club have always got bits and pieces for sale and are always willing to help out fellow members.
cheers
Chris
Knowledge is knowing a tomato is a fruit, wisdom is not putting it in a fruit salad
ESS KEE is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2011, 10:18 PM   #18
xg-ute
cheers dude, thats awesome ill get in touch with them.
cool thanks man, might join up when i get her looking a bit more respectable!
Henry
Old 03-11-2011, 01:03 PM   #19
ESS KEE
ESS KEE's Avatar
Henry
no problems, although it doesn't need to be respectable to join! ha ha! mines along way off being finished
