Old 07-12-2011, 01:13 PM   #1
FG Brake
Default That little Falcon front spoiler vertical ledge.
Hi. This will make a change from all the high tech questions at least.
On the front under flat spoiler of the AU and our new falcon there is a flat vertical tab right across the car.
In my humble opinion I feel this would act like a sail brake and be counter productive in many ways.
It bugged me so bad on the AU I trimmed it off!
But before I do same to the Anniversary I just wanted to know if anyone out there knew of an intelligent reason to leave it there, I won't.
FG Brake is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 01:14 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
Default Re: That little Falcon front spoiler vertical ledge.
helps to create a low pressure zone in the engine bay - aids radiator flow
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 07-12-2011, 01:20 PM   #3
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
I think that lip is there to give strength to the trailing edge to stop the air deflector flapping in the breeze and falling apart as the rear section is not otherwise attached to the car.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 01:22 PM   #4
Peuty
Afterburner + skids =
Peuty's Avatar
This.
Oo\===/oO
Old 07-12-2011, 06:01 PM   #5
Jim Goose
Im sure all that wind tunnel testing musta been a waste of time....
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 07:41 PM   #6
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Both reasons apply I reckon.
Cut it off and see how dirty your engine gets....
Jastel is online now   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 08:03 PM   #7
Silver Ghia
Silver Ghia's Avatar
The intelligent thing is to leave it there. As mentioned, it helps extract the cooling air from inside the engine bay while driving along.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 09:03 PM   #8
4VCLEVO
XA GT
4VCLEVO's Avatar
I pulled the whole black tray off, engine isn't dirty, it doesn't get hot and I can't see any differance with it off.
XA GT, 6.848sec 1/8 mile @ 101.68mph
4VCLEVO is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 09:15 PM   #9
jjw
powered by Ford
jjw's Avatar
Its definately there to pull more air through the radiator (don't know about the dirty engine theory?).
jjw is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 09:40 PM   #10
FG Brake
There is a bit of logic here as to stay Jewish or do da big cut.
But at the end of the day if this tab is possibly for radiator cooling, then 'at speed' it wouldnt be needed anyhow.
I will check for strenght first.
This flat 'cooling, aerodynamic and engine cleaning tab' on the FG is quite big at about 1" wide and I am now at 80% 'it has to go'.
As such I think it will be 'Wide Bar Kuts'mah' Aussie style, with Home Brew all round.
I will drink to it meanwhile as I ponders.
Old 07-12-2011, 10:07 PM   #11
Silver Ghia
Even more so at speed, its an aerodynamic thing to do with pressure differential. And not just radiator cooling but engine bay cooling as well. Every bit helps.
Old 07-12-2011, 10:14 PM   #12
2011G6E
2011G6E's Avatar
I remember reading in a guide to modifying WRX's that many owners are surprised when they lower the suspension, fit stiffer springs and roll bars, and play with the camber, that they end up with something that handles like a pig.
Occasionally, just occasionally, the guys who spent hundreds of millions of dollars developing something had a vague idea what they were doing...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 10:17 PM   #13
swanee
spoolin!
swanee's Avatar
Is it really that much of a problem?
Current Ride - 2016 FG-X Falcon XR6 Turbo Manual. Smoke Grey
Previous Rides - 2014 Black Mica PX XLT Ranger Dual Cab 3.2 Diesel
2011 FPV GS 315 Sedan. Sunburst, manual, fully optioned. Build #165.
My 1955 Ford Thunderbird Project (A tribute to my late mother) - 1955 Thunderbird Build Thread
swanee is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 07:54 PM   #14
xtremerus
FG XR6T trayback
xtremerus's Avatar
If it did SFA, Ford wouldn't have put it there, and saved a few buck.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 08:01 PM   #15
DJM83
Barra Turbo > V8
DJM83's Avatar
I dont get the issue really, its not that much of a hassle, although it might save you 0.00000000000000000000000001L/100 in fuel
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 10:07 PM   #16
Pinkbits
Pinkbits's Avatar
It also helps keep the underside of the front bar more rigid.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 11:55 PM   #17
Neale
Neale's Avatar
its suprising that things like this can make sutch a difference. one example is the rear spoiler on the old GT40, it looks like something that would slow the car down by inducing drag, but without it at high speeds the car would become so unstable it could crash.
This may not be the case with the lip on the front of the falcon, but im sure its been put there for a reason & im with everyone thinking it has something to do with cooling
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 09:46 AM   #18
DanielXR8
Clevo are you honestly suggesting that Ford missed an opportunity to cost cut something of a car that doesn't do anything.
I don't think so!
DanielXR8 is offline   Reply With Quote Multi-Quote with this Post
