Old 26-01-2012, 04:37 PM   #1
2002au
Define definitive
2002au's Avatar
Default ba brakes
hi everyone, looking at putting ba brakes on my xr6.
guessing all ill need is:
ba calipers,
ba rotors (going to get slotted)
ba pads,
brake fluid (dot 4?).
these all bolt straight up correct?
cheers
BF F6 TYPHOON in NEO #718 ~ 356rwkw :
BF XR6 TURBO in SILHOUETTE
2002au is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2012, 06:04 PM   #2
2002au
Define definitive
2002au's Avatar
Default Re: ba brakes
also do i need the ba lines? cheers
Old 26-01-2012, 07:58 PM   #3
BZINGA
Powered by Ford
BZINGA's Avatar
I think you need spacers if your using BA calipers .. not sure if it's xr calipers or standard or both so id ask about that.
I'm going BF xr8/6T/Territory fronts which bolt straight on.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2012, 08:03 PM   #4
2002au
Define definitive
2002au's Avatar
i think i read somewhere that you only need spacers if you have a series 1? could be wrong. mines a series 3 btw
Old 26-01-2012, 08:15 PM   #5
Day-mow
rexnet
Day-mow's Avatar
gotta use BA brake lines
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 26-01-2012, 08:48 PM   #6
BZINGA
Powered by Ford
BZINGA's Avatar
It came up when i was talking to the brake guy i know last week but as i said i can't recall if it was the standard or premium brake off the BA going onto the AU 2/3 ...
Long story short he said the BF option was better for what i wanted and was cheaper than the BA option but i'm upgrading to premium size not standard size.
Old 26-01-2012, 10:41 PM   #7
2002au
Define definitive
2002au's Avatar
just messaged "the monty" and he says its all a straight fit! win
Old 27-01-2012, 08:21 AM   #8
Day-mow
rexnet
Day-mow's Avatar
so BF XR8/6T/Terry brakes are bigger then a BF XT? and BA XR8? are they a 322mm rotor still?
whats a set of BF XR calipers worth?
Old 27-01-2012, 08:29 AM   #9
The Monty
Just slidin'
The Monty's Avatar
Yeah guys, take off an AU caliper, and the disc, put on a BA disk, and caliper, use the brake line that comes with the caliper, hook it up and your done, couldnt be simpler. And I deffinately did not use a spacer of any kind. The BA XT brakes and calipers when side by side with the AU's are quite an upgrade.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 27-01-2012, 07:37 PM   #10
Day-mow
rexnet
Day-mow's Avatar
so a BA XT set of calipers are all you need? winnnning!
what about the rear?
Old 07-02-2012, 11:19 AM   #11
2002au
Define definitive
2002au's Avatar
so my calipers just arrived from ftg autosalvage. and they have the ba lines but have been cut. so ill have to go to wreckers and get some, but what exactly am i asking for? the front ba falcon brake lines that go from the caliper to the....? sorry for stupid question but my brains not working well lol
cheers
Old 07-02-2012, 12:04 PM   #12
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Go buy new lines as you don't know how badly damaged the old ones can be
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2012, 12:06 PM   #13
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Cassidy, go into the supporters section, and go to Race Brakes Sydney - Get some braided BA lines....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2012, 11:33 PM   #14
Day-mow
rexnet
Day-mow's Avatar
you want BA lines. if u want to go braided now is the time because your going to bleed the system anyway with swapping calipers. but going braided fronts only doesnt do as much because the back will "swell" instead of having firm pedal feel like itwould with braided all round./
Old 08-02-2012, 08:11 AM   #15
The Monty
Just slidin'
The Monty's Avatar
Day-Mow, the calipers are the only change for the rear as well. Bolt straight on. The rotors are bigger, BUT, the calipers fit AU2/3 pads. So you can reuse the ones you have.
