Old 08-02-2012, 01:49 PM   #1
falconboy
Default Holden VR LWB Ute length
Does anyone know if these lwb ute ex-ambulance utes are really long in comparison to wagons? They look extra long but wondering if its an illusion because of the tray.
______________________________________
2006 BF MKII Winter White Wagon
falconboy is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 02:05 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Holden VR LWB Ute length
The VR/VS ambulances were not factory - iirc they were modified by Jakab or one of those companies.
Yes they were much longer than a wagon, by a good half a metre or so. If you look hard, you can find ones as new as 2000 models (VSIII).
Old 08-02-2012, 02:23 PM   #3
falconboy
Thanks, I knew they weren't factory, just wasn't sure of the length. I assume if that's the case they are a pain to park anywhere and I'm guessing tailshaft is custom too and expensive if repairs are needed? Might not be a great option.
Old 08-02-2012, 02:48 PM   #4
Mr Hardware
Remember a standard commodore ute tray is only about 2m long and so to add another half a metre you're only talking as long as a long triton tray (2.6 iirc).
Old 09-02-2012, 09:20 AM   #5
falconboy
Good point, not exactly a limo length really. Shame its not a Ford though......
Old 09-02-2012, 09:52 AM   #6
Smoke Pursuit
They made similar XH utes for a while...
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2012, 10:27 AM   #7
Mr Hardware
Yeah, but apparently the ford utes suffered from large amounts of rust at the seam because they just welded and spatter went everywhere....
Old 09-02-2012, 02:17 PM   #8
2011G6E
2011G6E's Avatar
I've seen a lot of tradies with them around the place...they're a lot longer than a normal ute and would seem to be well made given the massive amounts of crap I've seen guys pile into them...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2012, 03:13 PM   #9
Spammy
10 years ago when I was shopping for a Commy ute I was amazed how many of the LWB things were around and most of them had low mileage (at that time anyways).
Would be perfect to carry around motorbikes with that extra bed length.
Spammy is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2012, 11:52 PM   #10
falconboy
There are a few around and they aren't too expensive. I may be needing a commercial vehicle, and as much as a standard ute will do, these seem extra handy. I'd love to find one of the ambulance bodies to put back on one too.
Old 10-02-2012, 05:52 PM   #11
xtremerus
FG XR6T trayback
xtremerus's Avatar
I had a VR model, years ago. Bought it 1.5 yrs old with 60k on the clock.
They are extended 500mm, but it didn't drag its belly too much. It had the red airbags in the rear coils that the Ambos had in it.
Did a center bearing in the tailshaft. The extra 500mm in the shaft must have done wonders for balancing.
Sold it when the computer started to play up, and bought a new AUII V8 1-tonner traytop
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2012, 08:52 PM   #12
falconboy
No go, checked this out, it was a piece of you know what. :(
Old 11-02-2012, 03:53 PM   #13
oceanwave54
Ego driven XR6
oceanwave54's Avatar
A friend of mine just bought one for his trail bike, very smooth over speed humps, was very surprised, just sort of floats.
Apparently a lot have low mileage due to them being bought just when Ford was awarded the contract, so the Fords came into effect and the extended Holdens just sat around. Not sure of the merit, but it sort of makes sense.
1990 XF Falcon Ute White
1994 EF Fairmont Cardinal
2004 BA Fairmont Luscious
2007 BF MkII XR6 Upgrade Ego
oceanwave54 is offline   Reply With Quote Multi-Quote with this Post
