Old 02-03-2012, 05:13 PM   #1
JFJ
Default 07 Fiesta Zetec AUX problem
Hi All,
I know that it is a common problem with the 3.5mm aux input socket in the console and I have managed to make boh speakers work with a bit of creative lateral thinking (stuck a toothpick in with the plug to assist with connection!)..
The problem I seem to be having now is that it sounds like the signal is out of phase.. I am happy to pull apart the console to have a look at the wiring but I cant find the website that explains the steps.
Has anyone solved the same issue or have any insights as to how to remove the panel around the gear shifter?
Many thanks in advance!
JFJ is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 02:45 AM   #2
vhcbm
having Fiesta withdrawals
vhcbm's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Ford couldn't fix my BlueTooth issue. This member posted a download link, with instruction, on how to do it myself. One week on, the unit hasn't played up once. Three different dealers told me to virtually 'Live with it.
Default Re: 07 Fiesta Zetec AUX problem
Pretty sure it's just plastic clips, getting your fingers under it should click them off. All I can say is check for loose wires but remember there is power going to them.
New: Ford Focus RS in Ultimate Green number 82/315
Past: 2009 Ford Fiesta LX in Vision Blue - Sold
vhcbm is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 02:59 AM   #3
City1964
hi,
i also had a similar issue, sound only coming out of one speaker sometimes. just took the console cover off, removed the jack from underneath...it is held with pressure clips. i then reset the vertical metal contact by prising over with a jewellers screwdriver, thereby increasing pressure when inserted, and viola all fixed. about a year ago had to do this and so far all good.
City1964 is offline   Reply With Quote Multi-Quote with this Post
