03-03-2012, 10:34 AM | #1 | ||
I understand that all cars have to have a minimum ground clearance. Can any FF member tell me where said ground clearance is to be measured? On a 1993 Ford Telstar but also on any car?
03-03-2012, 10:37 AM | #2 | ||
Far aim aware it's from the chassis to ground could be wrong tho!
03-03-2012, 10:39 AM | #3 | ||
Lowest point of vehicle in NSW ... could be exhaust. It depends.
Last time I saw RTA do this check ... they slid a roller-type device under the vehicle and if it touched anywhere ... you were too low. 100mm is the legal lowest here.
03-03-2012, 10:39 AM | #4 | ||
lowest point apart from suspension arms
03-03-2012, 10:58 AM | #5 | |||
In QLD:
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
03-03-2012, 01:12 PM | #6 | ||
thanks people. I need this to work out how far my car is from standard ride height as am replacing tired (collapsed) springs with Kings and new Ultima struts. Not cheap...
03-03-2012, 06:37 PM | #7 | ||
in NSW its 100mm from the lowest part of the car. So esentially if you can roll a coke can on its side under the car & dont hit anything you will be fine.
If your unsure call up the RTA or Police Highway Patrol & they should beable to tell you |
03-03-2012, 06:50 PM | #8 | |||
03-03-2012, 06:55 PM | #9 | ||
Im pretty sure its the same in VIC. 100mm from the lowest point.
Is it taken when the car has a full load? |
03-03-2012, 07:00 PM | #10 | ||
Force Fed Fords
In Victoria 100mm from any part of the sprung part of the vehicle, anything north of the springs including exhaust, body kits etc
2021 Focus ST-3 Mountune Enhanced |
03-03-2012, 07:00 PM | #11 | ||
Oo\===/oO
100mm from the lowest point of the car, debatable if that means mudflaps. But it includes exhaust and hangers, anything... oh, and that's with a full size passanger and a tank of fuel.
I did see something somewhere about it being measured within so many mm of the axle centerline, but im not sure enough about that. A coke can is 110mm tall, if you cant fit one under, its a good sign that you've got an illegally modifed car. I can't fit one under mine
03-03-2012, 07:56 PM | #12 | ||
Rob
in s.a. there are 2 measurements to be aware of for vehicle height. ground clearance seems to be the same as other states but the car also must meet a certain 'hub to guard' height. thats centre of hub to lip of guard. your local tansport authority should be able to fill you in on what that measurement is.
