Old 26-05-2012, 05:48 PM   #1
Gezza1er
Gezza1er's Avatar
Default Phase 4 Engine
Hi Guys
A mate of mine is installing light posts and power poles for Western Power up north and some of them go through Big blocks of land.
He told me he saw a XA 2door and the owner said it had a phase 4 motor in it.
I thought they were only released in the the phase 4 but from what i can remember there were only 4 made 1 crashed 1 unknown of location and the other 2 owned some where. the owner of the car said that they made excess engines and just put them in the early XA's?
So the reason i stared the thread is what was the phase 4 motor. What specs,info,pics or anything to identify it if someone stumbled across one... and dose anyone on the forum have on their car.
If there's even such a thing as the phase 4 motor
Gerry
Gezza1er is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:12 PM   #2
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Default Re: Phase 4 Engine
Ahh yeah, you might want to find that thread on the XA GTHO Ph4 resto (the green dentist's car) which should explain it all.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:13 PM   #3
fordman302
fordman302's Avatar
isn't that what the rpo83 was derived from in some form or another?
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:15 PM   #4
Nikked
Oo\===/oO
Nikked's Avatar
Probally a RPO83
Not a full house spce Ho, but many of the parts that would appear in a HO.
You would have to compare the specs of the motor to the real HO to see whats what.
But, even then, its not a HO motor as such.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:27 PM   #5
gtxb67
moderator ford coupe club
gtxb67's Avatar
one was crashed and the other 3 are alive. while i and many others have no idea where at least 2 of them are, they are not really unknown
was he actually saying it came out of a phase 4 or was it built to phase 4 specifications
either way, i seriously doubt he had one of the genuine phase 4 engines - maybe an rpo like nikked suggested, but not a phase 4
gtxb67 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:37 PM   #6
xbxd351
xbxd351's Avatar
My guess would be an RPO 83 or replica and I'm pretty sure they only got HM headers and a 780 Holley.
Other possibility is he was pulling your leg. I do that sometimes because so many people come up and start yapping with you when you have a coupe and mine is just a boring old GT mock up Fairmont so I sometimes tell people it is a one off special Phase 4 coupe with factory B&M shifter
1972 XA Coupe 351 C10 The daily
1974 XB 393 C10 The other daily
1979 XD 351 Toploader Just for fun
xbxd351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:42 PM   #7
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
RPO83 was the body, many years ago I remember reading a story with Ian Stockings
from FoA who indicated that the Ph 4 engines went into ZF Fairlanes.
Can anyone verify if that's a red herring?
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:03 PM   #8
Pinkbits
Pinkbits's Avatar
Myths that have been doing the rounds for years are that they had parts bins on the assembly line & whatever excess parts were available were placed on cars at random.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:22 PM   #9
Nikked
Oo\===/oO
Nikked's Avatar
It seems to be the case that the only constant RPO83 options were the carb, headers and sump, both in coupe and hardtop form. Just over 250 were made, as per homologation requirements.
It good to note that the RPO83 wasn't that last "bathurst special" that ford sneekly brought out...
\≡≡T≡≡/
Old 26-05-2012, 07:46 PM   #10
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
I didn't think all RPO83's had the same extras. Some probably only got the wider wheels.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 08:32 PM   #11
wicko
wicko's Avatar
It could just mean its a V8 Ford - possibly even a 351.
wicko is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 09:09 PM   #12
ozrunner
I seem to recall that many of the excess 4 parts were basically fitted to whatever was coming down the line at the time etc.
But to answer you question, yes some obviously went into ZF's as back then I was having a bo peep at a ZF getting a new recon Clevo fitted at my local machine shop. I then spied a dirty Clevo on the floor nearby that was in pieces and it looked odd. Closer examination showed it had 4 bolt mains and a twin eared sump . I asked where did this come from and the reply was out of the ZF. The owner apparently didn't care either way as he just wanted a new recon engine fitted.
On asking I could have had the lot for $300. A week later I thought of it again and decided it would look good in my shed but as usual someone else didn't dither
ozrunner is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 01:24 AM   #13
k code
There is an yellow fire RPO with the engine out of crashed P4 that was recently sold on AMCS.So maybe that is the car..
k code is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 09:37 AM   #14
Gezza1er
Gezza1er's Avatar
The only other thing that he told me was it had a 6 ltr sump pan and from memory don't the normal 351's have 4 to 5 ltr sump pans. The owner said that it came form factory like that (supposedly)?
Old 27-05-2012, 01:03 PM   #15
castellan
ZF fairlane only got a 351 with 2V heads and 2BBL carby.
castellan is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:35 PM   #16
Bossxr8
Peter Car
Bossxr8's Avatar
They never actually got to the point of building the Ph4 motors, they had ordered some of the required 250 sets of parts and some had arrived, but they never actually went into production. They cancelled orders for parts that hadn't been made yet, sold off stuff to the aftermarket they could (they did that with the detroit locker 9 inchers), and all the other parts were used on the line at random just to clear the rest of it off. The headers and holley carbs were probably the only bits they sent out that were organised to fit to a particular variant in the RPO83.
The other stuff was fitted to anything that would fit, i've heard of the eared sumps being found on Fairlanes, F100's and Falcons.
Thats the most likely explanation.
The Ph4's were never going to have 4 bolt mains, thats a myth. The Calypso Green dentists car doesn't have a 4 bolt block.
There would be a Ph4 engine floating around out of the Ph4 that was written off, rumour has it that it went into a Coupe. Plausable but very hard to prove unless they could somehow match the engine numbers of it to the wrecked Ph4.
Old 27-05-2012, 03:03 PM   #17
bionic2006xr6t
bionic2006xr6t's Avatar
That's correct the production phase 4 dose not have a four bolt block. I have a magazine around somewhere from the 80's maybe early 90's that broke down the history of all the phase 4's owners etc. The phase 4 that was written off actually had it's original motor removed years before it meet it's fate. One of the previous owners son's was an up and coming water skier and he actually put the original motor in his speed boat. A standard Cleveland was fitted to the car and the car sold. On another note I have seen and have photo's to prove it (somewhere) I will see if I can find them of a Falcon 500 ex police car with an engine code of "H" on the compliance pate. As you all know "H" was the ho motor. The motor looked like any standard Cleveland but I didn't get time to check if it was the original matching numbers unit. The car was very run down and abused so it may not have been.
Cheers Ryan
bionic2006xr6t is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 06:04 PM   #18
castellan
Detroit lockers came std in all P5 LTD i thought.
Don't think winged sump could of been in F100's as they are different shape ?
A lot of other stuff most likely were not original from new and just put in after.
Old 27-05-2012, 06:24 PM   #19
RedHotGT
Long live the Falcon GT
RedHotGT's Avatar
Originally Posted by Gezza1er
Hi Guys
Gerry
Re: OP
I think you'll find that your friend was in fact talking about this car:
http://australianmusclecarsales.com....lcon-coupe-rpo
See the advert - claiming to have the engine from the Bruce Hodgson Ph4.
Otherwise - i'm sure we could all remember previous threads about the Ph4 and what is rumour and what is fact.
RedHotGT is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 06:29 PM   #20
k code
Thats the coupe i was talking about..
Old 27-05-2012, 07:06 PM   #21
Gezza1er
Gezza1er's Avatar
WOW what a nice car i wish i had the money to buy it... Anyway i think the owner must of been talking out of his hole. If i can i will c if i can get some photos of it to see if you guys can verify it . This i great info so far but don't stop the thread keep it going i would love to hear more info on the phase 4 motor
Gerry
Old 27-05-2012, 07:40 PM   #22
WMD351
Size it up
WMD351's Avatar
The phase 4 thread
http://www.fordforums.com.au/showthread.php?t=11284486
WMD351 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 08:35 PM   #23
Bossxr8
Peter Car
Bossxr8's Avatar
There's no way they fitted Detroit Lockers to LTD's.
As for the eared sump in F100's, I wouldn't know what shape they are, I just heard that some aussie built F100's ended up with some of the Ph4 bits, like any aussie built V8 at the time could have had.
Old 28-05-2012, 12:51 AM   #24
ozrunner
And many of these myths will probably go on forever.
But along with the eared sump this thing did have a 4bolt main block as I checked the engine number to actually see if it did come from the ZF and it was its original engine as it matched. The car was an old farmers and he didn't want to wait for his engine to be reconned and just wanted a quick swapover so he could get back to the farm.
Back then any significance to P4's etc wasn't on the horizon so it was just treated as an odd block and sump to be in a ZF, even by me. It was the strange looking sump that really grabbed my attention at the time.
Who knows maybe they were considering using them but changed their minds and as was the case with many other parts it also found its way into the ZF and we'll never know why or how but it did have the P4's eared sump.
Old 28-05-2012, 04:59 PM   #25
XAllent
The story of the coupe with the phase 4 motor will be coming out in a future issue of Street Fords Magazine.
A is Always the highest grade!
XAllent is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 08:05 PM   #26
bigwil
Yes i cant wait for that issue of street fords, Roy did an awesome job on the phase 4, now im just waiting for the phase 4 book he said was in the works.
bigwil is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 08:15 PM   #27
Nikked
Oo\===/oO
Nikked's Avatar
I love that the "supercar scare" didn't really do anything...Ford got its RPO...Holden still went ahead with the XU-2 program and Chysler still got a V8 charger.
If anything, emmisons reg and oil prices had more effect...
\≡≡T≡≡/
Old 28-05-2012, 09:11 PM   #28
XAllent
Yes, but not as powerful as they would have been!
Old 01-06-2012, 09:08 PM   #29
Gezza1er
Gezza1er's Avatar
dose anyone know the specs of the ph 4 motor and what made it different form the previous engines.
Old 01-06-2012, 10:37 PM   #30
Bossxr8
Peter Car
Bossxr8's Avatar
There wasn't much different.
Biggest change was the machined combustion chambers, which got rid of all the rough casting marks the previous engines had to cop. They could have high spots etc that could cause detonation.
All 250 sets of 4V heads were going to be hand machined in this area, which shows the lengths FSV were going to go to to make the Ph4. Would have cost them a lot of money to do that if it had of gone ahead.
