hi all im just wondering how hard is it to remove a sticker off paintwork without damaging the paint? and also what is the best method to do so?
thanks
THE SHED Daily - BA Mk2 XR6 Turbo, Auto on 20s Long Term Project - XB Sedan, too much to do on this one But its a 351, 4speed with a LSD 9inch (Back over home in NSW) ![]() |
Use a heat gun. That usually works well just be careful not to overheat the paint.
Former BTIKD
![]() Join Date: Mar 2005
I've heard that a hairdryer works as well.
#4 | |||
#5 | |||
TuRbO
Noise does not = Power |
#6 | |||
depending how old it is and what kind of life it's had, you may encounter a difference in weathering of the paint (as long as it's thick enough you should be able to correct it though - just another thing to think about)
* 1973 ZF Fairlane 500 *
Heat gun usually does the job - but if it is extra stubborn, then a caramel wheel will get the job done. ( P&P repair shops use them ). Can be attached to a electric or cordless drill.
I just left mine parked in the sun and picked the sticked off with my finger nails (fingers were numb for a few hours after)..
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
i have done it in the past on a red daihatsu that was about 10 years old, and there was no fading that i could notice.
hopefully if a red daihatsu of that age can get good results a newer ford should be ok. i used a hair dryer to warm the sticker/glue up and carefully peeled it off.
-Tim |
HUGE MEMBER
Hair dryer, Yes
Heat gun, Never. Like said above, sunlight is worth a go first
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure My cruiser. 1979 Zh Marquis. "T" code 351. My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1. My dog. 2011 Sierra My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue Wanted Borg Warner Lsd or centre. 25 spline |
#12 | ||
playing in my big shed
depends a lot on the age of the sticker and how much its been in the sun / weather.
if the sticker is still reasonably fresh it should just peel off easy. if its a bit old and harder then warm it up a little ( warm , not hot) with hair drier, heat gun ( becareful not to scorch the paint), sun whatever and hopefully it will peel off ok. may come off in bits but be patient and keep picking away (finger nails ). eucalyptus oil can help soften the glue and once you get the vinyl film off eucalyptus oil and a rag is good for cleaning away any residual adhesive. a final clean with paint cleaner or fine polish should tidy it up. if the sticker is realy old and baked on, then you might need to sand it back and repaint.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
Caramel wheel.
#14 | ||
Hair dryer works a treat.... Just don't let it be yours missus' GHD... They don't like that... At all
#15 | ||
You can call me Chris
bunnings sell a citrus cleaner, gets rid of any adhesive that's left over. comes in a clear bottle with blue label, works a treat.
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
#16 | ||
XH Ute fan
We use a heat gun at work (dealership) and have never had a problem. Obviously you need to watch what your doing. Otherwise a caramel wheel works well. Again be very careful. Very easy to destroy paint.
#17 | ||
thanks for all the comments and help but ive been lucky and found another car and it hasnt got any on it (thank god) but now that leads to what is the easiest/best way to remove a badge off the body without damage.
#18 | ||
to much rubber
sign places usually use steam mops and guns from what ive seen to remove vinyl and badges
#19 | |||
Oo\===/oO
Why not a heat gun? They have temperature and speed control.
#20 | ||
When in doubt-MORE BOOST!
Heat gun is fine. just heat the area as evenly as you can and then get a corner lifted and heat as you remove. Wax and grease remover will get any residue off. Best way is to combine both methods. Park the car in the sun fo r a while to warm the panels up and then heat the stickers with a heat gun and way you go. I removed the stripes off my GTP and after a clean you would never know they were there.
#21 | ||
Go the Hogster!
I've just used a hair dryer in the past and then used some wax to remove all the residue. That was on some stickers that were 4 years old.
Nitro XR50 - the last brand new one in OZ ![]() first registered Oct 2011. |
#22 | |||
#23 | ||
I remove stickers with a heat gun all of the time at work as a signwriter & have never cooked the paint.
As long as you dont concentrate the heat in one spot for a long time, it wont be a probem. The sticker will burn before the paint anyway, so if you see the sticker starting to discolour then you know its getting too hot Just remember theres no point getting the sticker any hotter than you can touch or you cant grab it to peel it off. |
#24 | ||
LIVE TO DRIVE.
thanks it was worth looking this up.Hair dryer did it for me.
