Bseries
Hey guys quick question. The missus has an AU forte and I was wanting to if upgrade the standard 3 speed indicator/wiper stalks to the higher-end Fairmont ones with the intermittent wiper blade adjustment. Do i just replace the stalks? Or is there a seperate module or something to install?
Also, n00b question, is there an easy fix to squeaking wiper blades? Replaced them with brand new ones, still squeaking. Cheers Matt
His: 2003 BA Fairmont in Arctic White/Mercury Silver Hers: 1999 AU Forte in Amaretto Check it out: http://fordforums.com.au/showthread.php?t=11336211 |
#2 | |||
Former BTIKD
![]() Join Date: Mar 2005
Upgraded BEM is needed ... XLS utes had variable intermittent ... so it's a mid-range BEM you are probably after to get this working.
Bseries
Thanks for that guys. I replaced the whole blade.
Looks like this could be a bit more complicated then I thought.
When in doubt, GAS IT!!
Did you replace them with rubber ones or silicone ones. The silicone are a ***** and squeal like a schoolgirl? Also give your windscreen a once over with a good cleaner, windex perhaps although I like metho and water @ 50/50 mix myself, as depending on where you are your screen can develop a film of contaminants that can make the rubber squeak.
Bushbasher
