Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 18-07-2012, 09:32 AM   #1
BaraFGXR6
BaraFGXR6's Avatar
Default Getting more bite!
Hay Matt,
Thought id post this up rather than a PM in case any members had experienced the same issue
So far my break system is stock at the rear but upfront is the C5 caliper kit which consists of
PBR C5- calipers,
PBR pads
325mm discs
Braided lines (think they were good ridge from memory).
Over all the breaking performance is very positive and does pull the car up incredibly well when you stamp the pedal but its the initial bite that has me a bit wanting.
I wouldnt describe it as spongy but the pedal feel for very light breaking is a bit weak to the point where i cant tell if it is breaking or not - once pushed a bit further, i begin to feel the breaks come on and do their thing very well.
Is there a way to increase that pedal feeling a bit more? Im pretty sure i dont have air in the lines as i bled it around 2 months ago with no problem. However im going to bleed it a bit this weekend to make sure there is still no air bubbles.
Is this more of a pad issue or would it be due to the rears still being standard lines and the fronts being braided (i.e., do the rear lines start to expand a little bit and take away that instant feeling?).
Ford seem to think its fine (as always) however im interested to know if it might be something simple as a pad swap and rear braided lines or something more sinister like the ABS system requiring to bled.
Cheers,
Dom
2004 SR5 Hilux manual - totalled.
2008 FG XR6 manual - sold.
2010 XR5 focus (the beyernator) - sold.
2012 Navara STX manual - sold.
2013 Focus ST - sold.
2015 XLS ranger auto - sold.
2017 VW Golf work car.. current..
Originally Posted by Adrenaline
I'm going to convert my turbo to NA, just to see your head explode.
BaraFGXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2012, 11:42 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Getting more bite!
Originally Posted by BaraFGXR6
Hay Matt,
PBR C5- calipers,
PBR pads
325mm discs
Cheers,
Dom
That is basically what the BA GT came out with anyway only the rear caleipers were painted and had slotted rear discs but the rear brakes are the same size otherwise.
Are the bleeder nipples at the top of the caliper pointing upwards and are the pads secondhand or new PBR ones?
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 18-07-2012, 12:57 PM   #3
BaraFGXR6
BaraFGXR6's Avatar
Double nipples and new pads that came with them (same set I bought off you when you had them on clearance).
