Falcon Unbelievable!
G'day All,
Anyone got any ideas for modifying the location and/or the type (ie how to get rid of that stupid nut) of the fuel filter on the AU's?? I had previously thought the most stupidest part on an AU was the sump plug but after attempting to replace the fuel filter I now know it is the fuel filter nut. Even following the replacement guide and the gregory's guide all you really end up doing is stripping the head of the nut and needing to replace the fuel line. Probably needs very high quality/good fitting spanner to avoid stripping the nut. You would think for an item which needs to be regularly replaced it would be better located and designed. Don't get me wrong I love my AU but really there are just some things you would love to change about the AU. eg fuel filter under the bonnet |
get yourself a set of these,
http://www.supercheapauto.com.au/onl...17#Description or tool shops will sell better brands too, i paid $20 for 1x sidchrome one years ago.
Money Talks, but all i ever hear is it saying Goodbye!! |
growing up is optional
As above but I bought one of these
http://buy1.snapon.com/catalog/item....e=&dir=catalog Never had a filter that beat me since I got it over 10 years ago. |
rexnet
Only problem I've ever had with them was getting it to seal properly.
![]() Join Date: Oct 2006
regards Blue |
As above, grab a flare nut spanner, i havent ever had a problem with mine
#7 | |||
will try that and see how I go thanks muchly Should try and get the Flare Spanner added to the how to guide. Last edited by SirHenry; 29-07-2012 at 07:32 PM. |
Yep , I needed to change fuel filters on the AU and Soarer . Both same sized lines and nuts .
Went to repco and bought a flare nut wrench ![]()
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
Update!
Got Flare nut spanner, very impressed by it very good buy at $6 Only problem now is need to find someone with the muscles of Samson to budge the fricking thing. After second attempt damn thing will still not budge. At least the head of the flare nut is not stripping with is good means the flare spanner is fantastic. Had enough mechanic can have fun with it although up on a hoist would provide valuable leverage you can get on car stands. I have now elevated Fuel Filter to number 1 position of most stupidest part on the AU just a smidgen above door actuators. Thank you all the for the help I will be very curious to see how much fun they have with it. |
Use a pipe over the spanner or double another ring spanner in the other end for more leverage . Make sure you are using a spanner on the filter as well , crack both in opposite directions and away you go . Once cracked its easy
Spray some penetrating oil in it might help loosen in up or hacksaw of by the old filter type with double hose ends and install that with a strong hose clamp
#12 | |||
I still want one to be like my old corolla, nice easy plastic in the engine bay easily accessible, unclip fasteners install new one and done. |
#13 | |||
Whats wrong with the sump plug ?
If you want more inches ,stroke it!! |
#14 | ||||
#15 | ||
There's a fuel filter???
I've been servicing my AU ute for the last 7 years, and never seen or heard of one. Where is it, and when should it be changed? |
#16 | ||
It's under the passenger side floor just in front of the rear wheel .
From memory it's 14mm or 9/16 on the fuel lines .
#17 | |||
#18 | |||
#19 | ||
My bad...
#20 | ||
Also not a good idea to run the lines dry . Injectors require fuel as their lubricant and can be damaged if run dry .
#21 | |||
#22 | |||
sliding by you...
What are you on about??? |
#23 | |||
All good now though the AU's are still one heck of a car IMO. ![]() |
#24 | |||
#25 | |||
