Old 15-08-2012, 02:43 PM   #1
whitetdci
Default Falcon rims for Mondeo?
Are they the same offset and stud pattern on the Foulcoon as the Mondy?
whitetdci is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 04:14 PM   #2
JimStone
Default Re: Falcon rims for Mondeo?
Unfortunately no, Falcon PCD is 5x114.3, current Mondeo is 5x108 and early stuff is 4 x 108.
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 05:01 PM   #3
Cambo351
Jag built with Ford money
Cambo351's Avatar
5x108 as it turns out is same as Jaguar X-Type, S-Type & XF, XJ from 03 onwards and the XK range 2006 onwards but you need to be careful of the offset.
Also regarding the center bore, depending on who you talk to Mondy is listed as 63.3mm, and the Jags as 63.4mm & 63.5mm. It's all the same since these 0.1mm variations are smaller than the tolerances on a produced wheel!
Once you have the offset of your existing wheel and the proposed wheel, have a look here Wheel-Tire - RIMSnTIRES.com
Ex: AU XR6, Mondeo ST200, AU3 TE50, NC Fairlane 5.0, XE ESP Turbo, XY Ute, XD ESP with a 351
Also have a Land Rover, and another Jag, somewhere...
Cambo351 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 05:07 PM   #4
Cambo351
Cambo351's Avatar
Oh and BTW 5x108 is also used by Volvo, and a number of other Ford models...
http://www.wheelfitment.eu/PCD/5x108/63.3/
http://www.wheelfitment.eu/PCD/5x108/63.4/
http://www.wheelfitment.eu/PCD/5x108%20/63.5/
Don't take those listed offsets for granted, the correct offset changes depending on the width of the rim...
Old 16-08-2012, 02:55 PM   #5
whitetdci
Thanks Cambo. I have noted (for better or worse) that there seems to be a few interchangeable bits with Volvos. What is the world coming to?
Old 16-08-2012, 03:33 PM   #6
Cambo351
Cambo351's Avatar
You'd be surprised at the parts interchangeability between certain Fords, Volvos & Jaguars...
Old 16-08-2012, 05:58 PM   #7
whitetdci
I think I will keep quiet about the Jag bit after ragging a friend out for so many years about having one. Mind you it was one of the old clunkers not the newer hoop da ones.
Old 16-08-2012, 06:06 PM   #8
Cambo351
Cambo351's Avatar
Ha Ha!
Yes they've come a long way since the 70's & 80's mate.
