28-08-2012, 08:38 AM | #1 | ||
The annoying one.
Hey all,
Has anyone put an AU Engine into a NA Fairlane before? Thinking about doing it, and if anyone has done it how hard would it be? |
31-08-2012, 09:02 PM | #2 | ||
i put a au engine in the ed fairmont, use ea-ed engine mounts either use single belt, use ef/el ac pump bolt it to ea-ed aircon bracket, space out aircon to use a ef/el tensioner or use xh tensioner and just bolt ef ac pump to ea-ed a c bracket.
use a distributor and coil take out shaft covering the distributor on the au engine and put in a distributor as aus used coil packs and eas to eds have distributor and single coils the ridges on the front angle part of the sump need to be cleaned up a bit with a angle grinder so engine can fit or try and make the multibelt fit but just use the single belt hope it helps |
