Old 24-09-2012, 06:45 PM   #1
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Default GM claims 'breakthrough' will make vehicles lighter, help fuel mileage
GM claims 'breakthrough' will make vehicles lighter, help gas mileage
LINK
General Motors plans to accelerate the replacement of steel with aluminum after researchers achieved what the company described as a "breakthrough" in welding technology.
GM hopes the technological advancement will boost fuel economy by making its vehicles lighter. Aluminum is lighter than steel, making it an enticing alternative when it is not too expensive. But several hurdles remain for aluminum, including production challenges.
GM believes it has solved one of those challenges: the frustrating process of welding aluminum body panels.
Blair Carlson, GM's lab group manager for lightweight material processing, said researchers at the company's technical center in Warren developed a spot-welding technology that uses a special electrode to help two pieces of aluminum clamp together.
He said the technology also involves a proprietary process for controlling electrical current and cleaning the electrodes, which use protruding rings to pierce the hard oxide surface of aluminum, enabling the metals to fuse together.
GM has already used the technology to use aluminum in the hood of the Cadillac CTS-V sedan and the lift gate of Chevrolet Tahoe and GMC Yukon hybrids.
"There's going to be a significant increase in the application of aluminum in our vehicles in the next five years," Carlson said. He declined to say how much weight GM believes it can save in the average vehicle using the technology.
Carlson said researchers happened upon the spot-welding technology by accident when they experimented with software during a test.
"As it turned out, it was like, 'Wow, that really worked, what did we do?' " Carlson said. "We had to go back and figured out what we did, and that actually led to a breakthrough in one of our patents in the area of controls."
GM has dabbled in aluminum welding before, dating back to the EV1 in 1996 and some SUVs in 1999. But the process needed to be refined.
While this is great news I think Jaguar, land Rover and now Ford is moving on with
Aluminium using a mixture of rivets, adhesives and welding.....
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2012, 06:58 PM   #2
Drizz06
XR50th
Drizz06's Avatar
Default Re: GM claims 'breakthrough' will make vehicles lighter, help fuel mileage
I work on land rovers all day and they are spot welded alu body's.
[SIGPIC][/SIGPIC]
Daily-2010 FG 50th Anniversary XR6 in Winter white Herrod Cat back + K&N filter + Tune.
Mrs- 2006 Focus Zetec in Titanium Grey
Runabout- 1997 XH longreach in white.
Project- 1976 ZH fairlane 500
Drizz06 is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2012, 07:10 PM   #3
jpd80
jpd80's Avatar
Jaguar is using special rivets and adhesives on XK, XF and XJ but the tech came for the Land Rover engineers...
3100 SELF-PIERCING RIVETS ARE USED
The new XJ’s body structure is a masterpiece of advanced, intelligent technology. A ‘team’ of 100 robots applies just over 3100 self-piercing rivets, and more than 100 metres of aerospace industry-sourced epoxy adhesive to bond the aluminium pressings, castings and extrusions together to create the very stiff and durable structure. Painstaking research and analysis, along with thousands of hours of computing time, have enabled Jaguar’s engineers to improve the construction process, optimising the use of different grades and gauges of aluminium.
And the new Range Rover is using the same tech too...
The fourth-generation, dramatically slimmed down Range Rover leads its ancestors.
The car’s aluminum body is riveted and bonded using aerospace engineering processes. On the Solihull body line, 328 robots look after major areas of assembly, including application of 3722 rivets of 17 types. More than 160 m (525 ft) of adhesive is applied. The car uses what is claimed to be the largest single automotive stamping in the world. Saving 3 kg (6.6 lb), the body side eliminates joints to give better structural integrity. The best aerodynamic Cd of the range is 0.34, a 10% improvement, the front grill having active vanes.
Old 24-09-2012, 07:27 PM   #4
SteveJH
No longer a Uni student..
Don't welds weigh less than rivets? I seem to recall welding leading to a revolution in another industry (shipbuilding).
Previous:
1992 Mitsubishi Lancer - Petrol/Manual/Silver
1997 Ford Falcon GLi - Petrol/Auto/White
Current:
2012 Ford Focus Sport - Petrol/Manual/Black
SteveJH is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2012, 08:43 PM   #5
Nikked
Oo\===/oO
Nikked's Avatar
Rivits are usually used when two sections of different steels meet.
Gluing and riveting is also preferred as repair shops don't have the welding equipment to accurately recreate what the factories do.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 12:37 AM   #6
mik
mik's Avatar
i`d rather have steel for a car body i think, yes it can go rusty, but it`s pretty easy to repair and takes a fair bit to dent up a panel.
Old 25-09-2012, 07:29 AM   #7
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Yes. We need a war and an aluminium welding revolution so we can pump out a bucket load of "Liberty Cars".....
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 08:00 AM   #8
2011G6E
2011G6E's Avatar
Yes, aluminium can be rivetted or glued...but they are talking about welding it properly on a large scale and cheaply done for mass production. That's been a real nightmare for the car makers.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 08:11 AM   #9
H.G
Driver Returns On Foot
H.G's Avatar
sikaflex has been around for years...
H.G is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 08:48 AM   #10
madmelon
Aluminium can be made stronger for less mass. For example, if the panels were made the same mass (by increasing the thickness of the sheet metal), it would have approximately 8 times the stiffness, despite only having 2.89 times the thickness. Or if you wanted a panel 50% stiffer than a steel equivalent, the aluminium would need to be 65% thicker but would only be 57% of the mass.
Don't be fooled into thinking that an aluminium panel is easier to dent because it is a less stiff material- its low density more than makes up for it's lower stiffness.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 09:24 AM   #11
jpd80
jpd80's Avatar
Jaguar and land Rover are so far in front of this with self piercing rivets and adhesives that bond stronger than steel,
I think GM is riding for a fall as I recall J/LR looked into this and it was a real liability if weld quality failed..
there's much less potential exposure to quality issues with rivets and adhesives than welding going awry....
Old 25-09-2012, 09:39 AM   #12
zilo
BANNED
zilo's Avatar
Build cars with complex welds and exotic adhesives and they will be written off much easier in the event of a minor collision.
You only have to look at chassis rails these days, yes they can be repaired, but the labour costs write the car off way too easily in my opinion.
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 11:43 AM   #13
boris
Please, there was an American university that in 2007 invented thermo forging for the car industry with uses carbon fibre to form chassis and body panels with the strength and rigidity of titanium. They built car bodies that were 40% of the weight at 60% of the cost. The car industry didn't pick it up because they have too much money 'invested' in steel. Please, you wanna claim 'break through', go carbon fibre then I'll take notice, but aluminium, talk to the hand!
boris is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 11:59 AM   #14
Flat Top
lid man
Gm go talk to (VAG) Audi ??? please breakthrough what spin!!! VF should be using ali bonnets etc no big deal
Flat Top is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 12:27 PM   #15
Rodge
Rodge's Avatar
Australian made cars need to spend more time in wind tunnells, is there a wind tunnell in Australia ? FG Falcon has a coefficient of drag of 0.35 which is one of the reasons why they use more fuel than is necessary.
I don't think making some of the body panels out of aluminium is going to save much weight but it will add to the cost of production. Looks like GM are trying to curry some favour with the public...bottom line is talk is cheap, just build them and we'll see.
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 12:45 PM   #16
Road_Warrior
Pity the fool
Road_Warrior's Avatar
The current gen Ford Explorer uses an aluminium bonnet, so Ford must have gotten the mass production thing with ally sorted somehow.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 03:40 PM   #17
madmelon
Not sure where you're getting all that from...
Ford hasn't published drag coefficient data for the FG but I doubt it would be worse than AU or BA, which were 0.295 and 0.29 respectively. This has minimal impact to city driving compared to vehicle mass.
If you don't think aluminium can make a big difference- compare the X308 to the X350 series Jag XJ. They lost about 200kg through the move to an all aluminium structure whilst gaining a substantial amount of kit and structural stiffness. An even better example is the latest Range Rover to be released: some 470kg lighter due to all aluminium construction and the equivalent Discovery is expected to be some 500kg lighter.
Obviously it adds cost but there will come a time when more manufacturers are using lightweight materials than not.
Old 25-09-2012, 03:46 PM   #18
Mad_Pom
Don't forget the Lotus Elise, which have being using glue Alluminium since 1996. They glued instead of rivets to avoid stress fractures and it was actually shown to be stronger
Mad_Pom is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 03:53 PM   #19
jpd80
jpd80's Avatar
And that work on carbon fibre brought the cost way down from over 300/kg to under $30/kg but the
problem is that carbon fibre is still around $22/kg where as steel is around $5/kg and Aluminium somewhere in between.
The fact tha Mulally ordered a thorough review of the costs of composites which concluded that they are still too expensive
is the main reason why you're seeing the push on Aluminium in next F150 , having a global glut on supplies also helps too..
Old 25-09-2012, 04:08 PM   #20
Rodge
Rodge's Avatar
Autocar N.Z. quotes the SC GT at 0.35.
Yeah there's lots of noise about how much weight the very expensive process of building all aluminium cars can save but the bottom line is the all aluminium current XJ Jaguar and all aluminium Audi S8 are both significantly heavier than a SC GT, go figure...and that's before we even consider the extraordinary amount of extra cost this build process adds.
BTW Mercedes-benz also makes use of extensive aluminium in its S Class and that weigh's 2082 kg's with a full tank of fuel.
Despite all the extra costs where's the aluminium weight savings on large sedans ?
Old 25-09-2012, 04:38 PM   #21
Dr Smith
Could it be that on a lwb car when you add electrically assisted boot & door closing, powered rear seats, heated seats, all the airbags, sunroof, plus any other tech, a non aluminium car would weigh even more.
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 05:25 PM   #22
jpd80
jpd80's Avatar
And that is only an estimate..... Wikki quotes 1998 AU at 0.295, 1995 Falcon 0.31, I would expect that the regular FGs are just as good if not better...
VN Commodore = 0.34
VN Group A = Less than 0.30
VT Commodore = 0.32
Monaro = 0.31
VX Commodore = 0.329
VX Commodore SS Spoiler = 0.354
VY Commodore = 0.319
VY Commodore S Spoiler = 0.326
VY Commodore SS Spoiler = 0.334
VE Commodore = 0.354
VE Commodore Series II = 0.330
VE Commodore Series II + Rear Wing = 0.35+
WK Statesman = 0.30
ECOmmodore = 0.28
XF Falcon = 0.42
EA Falcon = 0.34
EF Falcon = 0.31
AU Falcon Sedan = 0.295
AU Falcon Wagon = 0.341
2010 Toyota Prius = 0.25
2002 Toyota Camry = 0.30
2003 Toyota Camry = 0.29
2010 Toyota Camry Hybrid = 0.27
2007 Toyota Aurion = 0.301
2007 Toyota Aurion Sportivo = 0.292
Old 25-09-2012, 05:46 PM   #23
Nikked
Oo\===/oO
Nikked's Avatar
Yes, and those cars would have weighed much more with normal metals and construction...
If you wieghed the bare shells, the likes of a Jag, Audi etc would wiegh less then the FG...
\≡≡T≡≡/
Old 25-09-2012, 06:03 PM   #24
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Range rover/Landrover had alinimum bodies years ago....60's or 70's????Maybe earlier....Might be wrong with the brand but it's ben round for a fair few years.
Gluing panels has been round for ages too....It's still in use....Recently I watch a program on Peterbuilt trucks...They glue the majority of the cab together.
So nothing new with techology
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 25-09-2012, 06:23 PM   #25
Nikked
Oo\===/oO
Nikked's Avatar
Bugatti used it in the 30's
\≡≡T≡≡/
Old 25-09-2012, 06:37 PM   #26
jpd80
jpd80's Avatar
What's new is that resources are better and more cost effective making lighter affordable cars a real possibility.
Old 25-09-2012, 07:29 PM   #27
Falcman0o7
Falcman0o7's Avatar
So now it's going to be a ULFE SIDI Dierct Injection Commodore.
Ultra
Light
Fuel
Efficient
Spark
Ignition
Direct
Injection
Direct
Injection
Sounds good ay!
Falcman0o7 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 07:33 PM   #28
Falcman0o7
Falcman0o7's Avatar
Yes but if holden use it then its NEW TECHNOLOGY.
Remember......The commodore has SIDI! Spark Ignition! I mean whoa....Thats a first for any combustion engine.
Old 25-09-2012, 08:32 PM   #29
Pub247
Resident F1 Troll
Pub247's Avatar
There's one in the monash uni campus in clayton... has a dyno in it aswell..... and haven spoken to the engineer that works there i can tell you that car makers do use it
Pub247 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 08:48 PM   #30
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
It wouldn't surprise me if BA or FG had a rise in Cd over AU, which had a noticeably slippery profile to the front end.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
